flywheel question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2011, 02:56 PM   #1
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
Default flywheel question
Will a flywheel from a 351 work on a 300? both are EFI engines, late 80's -early 90's. Thanks.
big_ol_bronco78 is offline   Reply With Quote
Old January 11th, 2011, 03:01 PM   #2
Dieselguy123
If I remeber right the 300 is a neutral balance flywheel, while the 351 has some external balance. I do thnk they will bolt up though.
Dieselguy123 is offline   Reply With Quote
Old January 11th, 2011, 03:39 PM   #3
eagle-eye
No, they dont interchange. have this problem with a 300 to 302 swap im doing. 300 is internally balanced, 351 has 50 oz. external balance i believe, same as a 302.
eagle-eye is offline   Reply With Quote
Old January 11th, 2011, 04:50 PM   #4
big_ol_bronco78
Psalm 40:2
thanks.
Old January 11th, 2011, 07:27 PM   #5
Quiefinator
go'til itsounds expensive
I think one is a 52 balanced and the 302 is like a 28 unbalanced. 351 and 302 are different IIRC.
Page generated in 0.17744 seconds with 38 queries
