4x4 700r4 for 2.8L V6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2011, 01:42 PM   #1
Bullet
Bullet's Avatar
Default 4x4 700r4 for 2.8L V6
I'm looking for a 700r4 automatic trans (and transfer case if available) 4x4 with the GM Metric bolt patten that would bolt to a 2.8L V6 in a early S-10.
Bullet is offline   Reply With Quote
Old January 11th, 2011, 10:50 PM   #2
TBSdontstop
TBSdontstop's Avatar
I have a transfer case that worked great. 75. obo
TBSdontstop is offline   Reply With Quote
Old January 12th, 2011, 08:36 AM   #3
Bullet
Bullet's Avatar
I need to find the trans first but I will keep you in mind on the transfer case.
Old January 13th, 2011, 05:48 PM   #4
hoyt5885
hoyt5885's Avatar
i have trans and transfercase from a 91 s10 blazer behind a 4.3 pm me
hoyt5885 is offline   Reply With Quote
Old January 13th, 2011, 11:22 PM   #5
Bullet
Bullet's Avatar
Sorry but it has to be from a 2.8L v6 not the 4.3. The 2.8L uses the GM metric bell housing bolt pattern which is different from the 4.3 / sbc bell housing.
I believe the 2.8L was used in 4x4 s-10 between 1982-88
Old January 13th, 2011, 11:31 PM   #6
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
If I remember correctly the 2.5 had the same bellhousing bolt pattern and the 2.8 was used all the way up into the early 90's
Old January 13th, 2011, 11:39 PM   #7
ronprice
ronprice's Avatar
4cyl yj and xj and 2.8 xj' trans will work for you too
ronprice is offline   Reply With Quote
Old January 14th, 2011, 08:48 AM   #8
Bullet
Bullet's Avatar
I know the 2.5 was the same bellhousing but I didn't think the put it in a 4x4 truck....
I hadn't thought of the yj or xj. What transmissions did jeep use? Was it a 700r4 or a jeep trans?
Old January 14th, 2011, 10:07 AM   #9
ronprice
ronprice's Avatar
I would need a jeep for my app. but you could use either. The jeep isnt a OD trans like the r4
Old January 14th, 2011, 04:28 PM   #10
ChevyRacer1981
Yes they did. rare but they did.
Old December 12th, 2011, 02:41 PM   #11
Bullet
Bullet's Avatar
Still looking for a GM 2.5L or 2.8L 700r4, metric bellhousing transmission. I don't care if it is 2wd or 4wd trans, mainly looking for a case.
Old December 12th, 2011, 03:00 PM   #12
skife
skife's Avatar
a guy on here just gave one away a few months ago.
Old December 12th, 2011, 04:59 PM   #13
Bullet
Bullet's Avatar
That's my luck. Hopefully someone else on here has another one to give away. I think 99% of these transmissions have already gone to scrap....
Old December 12th, 2011, 05:06 PM   #14
Wramblerguy
Wramblerguy's Avatar
why not go with the t5 manual?
Old December 12th, 2011, 05:12 PM   #15
Jimmysjeep
All about the cubicles...
Jimmysjeep's Avatar
Probably because he doesn't want to add a clutch pedal.
Jimmysjeep is offline   Reply With Quote
Old December 12th, 2011, 05:17 PM   #16
Wramblerguy
i know somebody like that
Old December 12th, 2011, 06:11 PM   #17
Bullet
Bullet's Avatar
It already has a clutch pedal I am removing. I'm lazy and don't want to manually shift.
If anyone wants I have a complete AX-15 & t-case for sale....
Old December 12th, 2011, 10:49 PM   #18
Wramblerguy
Do u have a 2.8l to ax15 bell housing??
Old December 13th, 2011, 09:30 AM   #19
Bullet
Bullet's Avatar
No I don't. The ax-15 I have was behind a 4.0L in a 99 Cherokee.
Old December 14th, 2011, 07:54 PM   #20
ChevyRacer1981
http://saginaw.craigslist.org/pts/2725753585.html
Tags
700r4, s-10
Page generated in 0.30846 seconds with 83 queries
