Anti Wrap bar - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 10th, 2011, 07:37 PM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default Anti Wrap bar
So i've been looking to put one on my blazer and there's many different kinds. One has a shackle others don't. Is the reason for the shackle because you can still articulate or is there another reason?
Old January 10th, 2011, 07:38 PM   #2
kj kyle
kj kyle's Avatar
just for flex.
kj kyle is offline   Reply With Quote
Old January 10th, 2011, 07:39 PM   #3
boggin-machine
boggin-machine's Avatar
to me the shackle idea is worthless. as it will still allow the axle to rotate since the shackle will just move forward.
Old January 10th, 2011, 07:43 PM   #4
DCX
out to lunch
DCX's Avatar
Interesting.
DCX is offline   Reply With Quote
Old January 10th, 2011, 07:53 PM   #5
boggin-machine
Originally Posted by DCX View Post
Interesting.
am i wrong in thinking that? the axle doesnt move in much of a arc as it does up and down. i dont see a need for a shackle as it will jsut allow the axle to rotate.
im sure im missing something here as im half asleep.
Old January 10th, 2011, 08:02 PM   #6
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
The shackle has to be the same length and angle as the one on the springs for it to work properly
BAD93SBLZR is offline   Reply With Quote
Old January 10th, 2011, 08:02 PM   #7
kj kyle
kj kyle's Avatar
think of it like a lever. the force is pushed down throught the shackle, to the cross member. not forward and back. the forward and back movement of the shackle makes up for the length change when the axle articulates, like the slip in a driveshaft.
If it didnt work, their are a lot of well built rigs with about 40# of scrap metal on them then...
Old January 10th, 2011, 08:04 PM   #8
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Kyle nailed it.
Old January 10th, 2011, 08:09 PM   #9
jonzer12
The shackle will still prevent the axle from rotating it, you just want to make sure it is mounted more or less verticle.
The only non shackle kind I have ever seen had a slip joint build into the body of the arm. The anti-wrap bar needs some expansion to deal with the wheel base change coming from the leaf springs.
jonzer12 is offline   Reply With Quote
Old January 10th, 2011, 08:22 PM   #10
boggin-machine
ahh that makes sense now. i guess i never thought about it. it never crossed my mind much either. thanks man
Old January 10th, 2011, 08:51 PM   #11
The shackle helps with articulation but does not solve the problem completely. If you lay out the motions as the axle moves up and back, the shackle forces the axle to wrap slightly. With that, it now wraps in a controlled manner, rather than bouncing all around.
Old January 11th, 2011, 06:26 AM   #12
Hoss Blazer
!SPARTY ON!
So which one would be better...Ladder bar or anti wrap bar? There gonna go on my blazer that i run mud boggs and trail ride with
Old January 11th, 2011, 10:14 AM   #13
liv2mx
i like jungle gym's.
liv2mx's Avatar
i like the second one.keep the shackle mounted out of the way. the seperation at the axle makes a difference and so does were it is mounted on the axle.
Old January 11th, 2011, 10:28 AM   #14
bigblocked
bigblocked's Avatar
Definately go with a shackle setup. I found that running the shackle at about 45 deg. gives me the most flex both up and down and still controls wrap pretty well. You can put together a pretty nice setup with a ladder bar (as long as possible) and a regular leaf spring shackle (again, as long as possible). Make sure that you use the backing plates for the ladder bar so that you can weld it to your axle tube 360 deg. because there's a ton of torque applied to the bar.
bigblocked is offline   Reply With Quote
Old January 11th, 2011, 10:53 AM   #15
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
The fullsize chevy guru has what you need.
http://offroaddesign.com/catalog/tractionbar.htm
Old January 11th, 2011, 12:17 PM   #16
Hoss Blazer
!SPARTY ON!
Nice.....but very expensive! I think i'm gonna make mine the same way as that one though
Old January 11th, 2011, 01:14 PM   #17
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
There you go. That is what I would do.
RIP FULLSIZE4LIFE
Page generated in 0.36013 seconds with 74 queries
