zf trans question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 10th, 2011, 05:05 PM   #1
camoII
camoII's Avatar
Default zf trans question
Ok so I'm helping my brother make his 97 f250 powerstroke 2wd a 4wd. He's got the 5 speed zf trans in it. The 4x4 zf's are hard to come by but I found a 2wd version with the brake on it and apparently you can put a transfer case on the back of this version? The brake comes off and the case goes on? Is this true and do you need something between the case and the trans? Or does the transfer case just bolt right up?
camoII is offline   Reply With Quote
Old January 10th, 2011, 09:36 PM   #2
Dieselguy123
If it is the style with the brake drum on the back they are the exact same transmission as the 4x4 zf, Just pull the brake assembly off and bolt the transfer case on.
Dieselguy123 is offline   Reply With Quote
Old January 11th, 2011, 02:22 PM   #3
camoII
camoII's Avatar
ok awesome. Just wanted to make sure. Thanks!
Old January 13th, 2011, 09:24 PM   #4
Hoofinit
Hoofinit's Avatar
Wow, good to know, that opens the door a little at the scrap yard.
Hoofinit is offline   Reply With Quote
Page generated in 0.17931 seconds with 35 queries
