My YJ I have been building. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 10th, 2011, 11:00 AM   #1
insane88yj
insane88yj's Avatar
Cool My YJ I have been building.
Well figured I would start a build thred on here on my YJ I have been building slowly. Couldnt get pic to work as of now. Will try again soon.
Has comp cut body, JCR cage, Rear piece cut off frame & tubing welded in place rear spring mounts moved back 6" shackle mounts welded into bottem of D ring tabs by JCR, rock sliders welded to frame by JCR. I am going to run XJ springs in rear & rear YJ springs in front.
D44 in front 14bolt in rear both with 4.10's for now. Thinkin spool in rear unsure if locker in front or not. Rear has disc brake conversion done.
Going to run mildly built 350 with th350 trans (thinkin 2000 stall mabie) & DANA 20 T-case. For tires 38.5x11x15" boggers.
Here is pic with stock axils still under it.
Pic of hood I had made for it.
insane88yj is offline   Reply With Quote
Old January 10th, 2011, 11:30 AM   #2
caveman
GeoDude
caveman's Avatar
looks sweet....
Old January 10th, 2011, 11:36 AM   #3
insane88yj
insane88yj's Avatar
Had issues with getting pic to work.
I will try to get more curent pics soon. Once I get it together enough to move it out to do so.
Old January 10th, 2011, 11:39 AM   #4
caveman
GeoDude
caveman's Avatar
is that the glass tub you had?
Old January 10th, 2011, 11:44 AM   #5
insane88yj
insane88yj's Avatar
No its the steel tub that I got for the glass tub the 1st time I traded it off. Then getting it back to trade it off again. Long story.
Old January 11th, 2011, 12:13 PM   #6
hellspawn
hellspawn's Avatar
Look's nice
hellspawn is offline   Reply With Quote
Old January 11th, 2011, 04:30 PM   #7
insane88yj
insane88yj's Avatar
Thanks!
Cant wait to get it together & running.
Page generated in 0.18513 seconds with 44 queries
