***FOUND*** 4.2 crank and rods ***FOUND*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2011, 02:26 PM   #1
ArcticCat843
ArcticCat843's Avatar
Send a message via AIM to ArcticCat843
Default ***FOUND*** 4.2 crank and rods ***FOUND***
Closer to battle creek the better.....want a 12 counter weight.
Anyone got one laying around?
ArcticCat843 is offline
Old January 9th, 2011, 02:44 PM   #2
martianjeep
too broke to wheel
martianjeep's Avatar
yes i have one. also have the rods/pistons.
martianjeep is offline
Old January 9th, 2011, 03:03 PM   #3
dmcjeep
dmcjeep's Avatar
I have a complete 4.2 from a 1983 that you can have for $100. No idea what a 12 counter weight is.
dmcjeep is offline
Old January 11th, 2011, 07:19 PM   #4
ArcticCat843
Ive changed my mind after alot of reading.....Everyone says go with the 12 cw crank because it will give you better low rpm power and more torgue....That really doesnt sound like it will fit my driving style.....I want a 4cw crank now....
Which from what i have read that should be a 81.5 to 90 4.2s
ideal one is 87-90 out of a YJ. Anyone have one of those laying around?
Dmc....I have no way of transporting a entire engine is my only concern. Plus do you know for sure that none of the bearing surfaces are destroyed? If you pull the crank and rods out and everything looks good then ill give you 100 bucks and you can keep the rest of the stuff.....(i know your prob not interested in that but i just thought i would offer)
Old January 11th, 2011, 07:27 PM   #5
dmcjeep
dmcjeep's Avatar
I guess as long as I know for sure that you are going to buy it I would be willing to pull it apart. It is not a big deal taking it apart I was just being lazy. I will gaurantee that the bearing surfaces are good. I know it was a good running motor before it was pulled.
dmcjeep is offline
Old January 11th, 2011, 09:50 PM   #6
jeepguy74
jeepguy74's Avatar
i also have one from a 1990 yj that had no noise and good oil presure 100 and its yours...complete motor with intake and exhaust.....
jeepguy74 is offline
Old January 11th, 2011, 09:51 PM   #7
ArcticCat843
no offense but the last engine i bought was supose to be a good running engine and when i tore it apart i found metal everywhere and half a pistion in the oil pan. Which is kinda another reason i dont want to buy an entire engine.
Can you get the block casting numbers so i can verify this is the crank and rods i want?
Could i come get it friday afternoon sometime? (If the numbers end up being right of course)
Old January 12th, 2011, 12:00 AM   #8
dmcjeep
dmcjeep's Avatar
No offense taken. I do give money back when that shit happens though. I will try and remember to get them nubers tomorrow. Not sure that I can have it apart by Fri but will see what I can do.
dmcjeep is offline
Old January 12th, 2011, 08:57 PM   #9
ArcticCat843
Did you happen to get that casting number?
The numbers on the block should be
3235444
Then the crank casting number should be
3235477
If those match the numbers on it then i want it....
Old January 12th, 2011, 11:04 PM   #10
dmcjeep
dmcjeep's Avatar
3235444
3235477
No I played slacker all day.
dmcjeep is offline
Old January 14th, 2011, 08:41 PM   #11
ArcticCat843
Anyone else have one? I really need one this weekend. Still haven't heard anything from Dmc.
Old January 14th, 2011, 08:45 PM   #12
ArcticCat843
It would be almost a 7 hour trip to come get it. If you where 2 hours away I'd come get it but that's to far for me
Page generated in 0.21126 seconds with 59 queries
