XJ: Swapping 4.0's... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 7th, 2011, 06:49 PM   #1
serpentz28
It Happens...just jump it
serpentz28's Avatar
Default Swapping 4.0's...
I have a 96' jeep cherokee (4.0 HO) that has super low miles on it... My question is, can I stuff this motor into a beatiful 97 jeep cherokee with an already blown motor??? I am sure that some of the sensors have changed, which I could either swap the ends or buy new ones, but are the motor mounts the same? All the fuel system the same? I know they really didnt change these til late in 99 to the distributerless crap. Any feedback would be great! Thanks!!!
serpentz28 is offline   Reply With Quote
Old January 11th, 2011, 05:09 PM   #2
92xjr
build it to break it!
92xjr's Avatar
Yes you can do it and it's not very hard. But you will have to use every sensor and accessory bracket from the '97, including the intake manifold and distributor. There aren't too many sensors so it doesn't take too long. If you do it just take your time and look at everything before you drop it in (it is a lot easier to swap parts with both motors out).
The motor mounts are the same.
92xjr is offline   Reply With Quote
Tags
4.0, 4.0ho, swap, xj
Page generated in 0.15371 seconds with 29 queries
