building a ford front 9 in - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 7th, 2011, 09:57 AM   #21
Originally Posted by magley03 View Post
the shafts that i am useing are 97 d60 iner and superduty outer out of an 01 i am using the mono bearing for easy access the spline count is 35 on the iner 60
Dana 60 shafts fit dana 44 knuckles? And unit bearing outers to boot? Did you switch your plan? How are you using this part combo?
Something seems odd here...
Old January 7th, 2011, 04:04 PM   #22
bbaXJ
Yooper In Training
bbaXJ's Avatar
With a big enough hammer and enough booger welds anything will fit
Old January 7th, 2011, 10:24 PM   #23
magley03
magley03's Avatar
funny u said that about the knuckles i was just going to ask if dogde kuckles r bigger on there 44 the knuckles and c i have came off a 99 2500 and i looked at the c on my superduty and they r the same size as the dogde ones
magley03 is offline   Reply With Quote
Old January 7th, 2011, 10:27 PM   #24
magley03
magley03's Avatar
man i am dyslexic as hell
Old January 8th, 2011, 07:58 AM   #25
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Cause a 99 dodge 2500 was a dana 60
Old January 8th, 2011, 08:15 AM   #26
magley03
magley03's Avatar
thanks well i guess i got 60 stuff now.
Old January 11th, 2011, 08:43 AM   #27
OK, next obvious question... Ford superduty stubs work with dodge unit bearings? Might want to check that...
Old January 11th, 2011, 10:09 AM   #28
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
oh snap
Old January 11th, 2011, 01:01 PM   #29
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
I take back all productive comments I may have said. Do it right the first time.
ckupq is online now   Reply With Quote
Old January 11th, 2011, 08:38 PM   #30
magley03
magley03's Avatar
no ford bearings so i can have lock outs
Old January 11th, 2011, 08:53 PM   #31
bbaXJ
Yooper In Training
bbaXJ's Avatar
So you're putting a $2000 hub conversion on it too? You have A LOT more research to do here. Not all D60s are created equal....not even close. If you're using knuckles from a 99 Ram 2500 D60 then about the only parts that'll work will be 2nd gen Ram D60 parts, which are all crappy unit bearings. Get yourself some kingpin parts and be done with it.
Page generated in 0.32255 seconds with 56 queries
