258 with a supercharger??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2005, 08:37 AM   #1
trail junkie
Guest
Posts: n/a
Default 258 with a supercharger???
Anyone Know of any after market superchargers for a 258?? Or if it can even be done, I already have aftermarket howell tbi
Old November 6th, 2005, 04:47 PM   #2
I'd really look at a new head before supercharging it. The whole point to forced induction is to get more air into the chamber, and overall, the 232/258 heads didn't breath all that well..
I'd go with a 4.0 head or even a whole 4.0, there are superchargers for them, if I was to do it(which I wouldn't)
$$$$, though, no matter what. I'd go with either an AMC V8 or a Small Block Chevy..
Old November 6th, 2005, 10:59 PM   #3
biohazardbill
Guest
Posts: n/a
You can build a sb chevy.. AND super charge it for the cost of a supercharger for the inline 6
Old November 7th, 2005, 07:28 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
yep to do the the Avenger supercharger I put on a 2002 TJ was over $5,000. I
Old November 9th, 2005, 09:53 AM   #5
Kodiak
Hardcore Poser
Kodiak's Avatar
You should look up Jeff (Cobranco) on the MJ board. He is right in Zeeland. He built several Superchargers for late model TJ 4.0 258 I-6 (he owns a machine shop and fabs up his own brackets, mounts, etc). He might be able to help you and it would be significantly cheaper than going with a KB or Avenger, etc... if that is a factor for you.
I've personally seen his setup and it's top notch. I believe he was running around 6lbs of boost off of an Eaton blower.
HTH, Good luck.
Kodiak is offline   Reply With Quote
Page generated in 0.18834 seconds with 38 queries
