Some one please help me axle troubles!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2011, 04:20 PM   #1
belinger758
Default Some one please help me axle troubles!!!!
i have a 93 jeep ZJ Grand Cherokee.. Dana 30 front with 3.55 gears... i have replaced all seals and bearings (axle seales/bearing, pinion seal/bearings) new CV shafts wheel bearings and for some reason something in my diff is getting so hot that it is burnin the diff fluid and smokes horribly... i have replace everything and had a certified mechanic doit it all...this is the second time it has happened and i cant figure it out..please help me!!!!
belinger758 is offline   Reply With Quote
Old January 3rd, 2011, 04:22 PM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
bad bearing? gears set up to tight? have you tryed to spin the axle by hand with the tires and drive shaft off?
H.o.r.e
Old January 3rd, 2011, 04:23 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
sounds like to me that the gears are set up wrong!
H.o.r.e
Old January 3rd, 2011, 04:26 PM   #4
belinger758
thought that was the deal but all the gears are not tightened to tight and there was no shims. and with the tire off and drive shaft off spins smoothly no binding at all. second time it has happened
Old January 3rd, 2011, 04:26 PM   #5
fordf250man
fordf250man
fordf250man's Avatar
i would agree with bigbchevy, being certified just means they passed a test
fordf250man is offline   Reply With Quote
Old January 3rd, 2011, 04:29 PM   #6
belinger758
i said that because the guy knows what hes doing
Old January 3rd, 2011, 04:31 PM   #7
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
X2, and or improper carrier bearing cap torque. Continued use will result in failure. If something is making that much heat you should be able to diagnose it with a simple visual inspection upon tear down.
Old January 3rd, 2011, 04:38 PM   #8
belinger758
had everything out and there was no signs on anything rubbing together or getting hot...thats y im so confused...everything looks good once u get the burnt diff fluid off from it
Old January 3rd, 2011, 06:30 PM   #9
shawn
Resident HVAC/R Jambi
shawn's Avatar
There is only two things it could be, gears getting hot or bearings getting hot. What is the pre-load like on the pinion bearing? You said there is not any shims? If that thing is set up right there will be shims under the bearings on the carrier, and under the inner bearing for the pinion depth.
Old January 3rd, 2011, 06:36 PM   #10
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Originally Posted by shawn View Post
there is only two things it could be, gears getting hot or bearings getting hot. What is the pre-load like on the pinion bearing? You said there is not any shims? If that thing is set up right there will be shims under the bearings on the carrier, and under the inner bearing for the pinion depth.
x2
Old January 4th, 2011, 09:56 AM   #11
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
2nd time?
What was wrong with it the first time?
Did the same guy do the work both times?
Tags
jeep axles
Page generated in 0.23350 seconds with 56 queries
