Ford Techs 2004 Mountaineer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2011, 03:46 PM   #1
firehawk
Live Action!
firehawk's Avatar
Default Ford Techs 2004 Mountaineer
Friend of mine has a 2004 Mountianeer with the 4.0 and AWD. About 80,000 miles.
He said this morning he heard a noise and the car seemed sluggish like he was dragging something. From what he described I started to think it was the transfer case. He had it towed to my place and all seemed fine when I test drove it.
I think the AWD transfer cases have issues, any ideas what I should be looking for?
And does the Airbag Module need to be reprogrammed after the bags go off? It was in a front end crash and he had a guy fix it but I don't think he replaced the seat belts, not sure if they need to be. It was not that hard of a crash but enough for the bags to go off. I saw it before it was fixed and really it was not bad.
Old January 3rd, 2011, 03:57 PM   #2
frdboy
frdboy's Avatar
If the bags went off it will need a new module. Also the pre-tensioner(s) probably went off as well. I would advise to pull codes on the air bag sys. as you will be able to figure out what else needs to be replaced.
Old January 3rd, 2011, 04:12 PM   #3
firehawk
Live Action!
firehawk's Avatar
He said he did replace the module but I think it needs seatbelts.
Thanks.
Old January 3rd, 2011, 04:15 PM   #4
frdboy
frdboy's Avatar
Thanks.
The new module will need to be set-up/programmed as well.
Old January 3rd, 2011, 04:16 PM   #5
firehawk
Live Action!
firehawk's Avatar
Ok, that is what I needed to know also. Thanks.
Can anyone around Royal Oak or Ferndale do this for a little $$$ ?
After he gets the seatbelts in.
Page generated in 0.25067 seconds with 38 queries
