4r70w help needed - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 2nd, 2011, 03:44 PM   #1
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Default 4r70w help needed
i have a 97 f150 4.6 4x4 with the 4r70w and it seem's to pop out of 1st gear into a neutral-ish state if you give it any more than 1/4 throttle and will free rev. but if you let off the gas when it get's back down to about 1500 it will pop back in. now the next thing is if you place it in manual 1st it will not do this.... the trans fluid is still red and not burnt smelling. i did a filter and fluid with the recomended mercron v after this started to see if i could buy some time and it has not helped. the problem is worse once the trans is warm and im stumped on this one. also in manual 1st it dose not slip in 1st gear soo it is not a slipping problem
beaterk5 is offline   Reply With Quote
Page generated in 1.59311 seconds with 26 queries
