4.10 to 3.42 for better fuel mileage? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 29th, 2010, 05:18 AM   #1
JoshG
Default 4.10 to 3.42 for better fuel mileage?
I have a 1998 3/4 diesel 4x4 suburban and the 6.5 has a #8 cylinder wall crack, so I am rebuilding a 6.2 that I got for cheap (don't have a lot of money and needed something economical).
The 6.5TD ran at 2500 RPM's at 72mph and I think the truck would have a tic increase in fuel mileage if I had 3.42 gears coupled with the 6.2 engine.
What do you guys think? Is it possible/practical? Would the truck more likely be running around 1900rpm's with the different gears? Did they even make a 3.42 front differential that will bolt in place of my 4.10 or will the best I'll be able to do is the 3.73?
JoshG is offline   Reply With Quote
Old December 29th, 2010, 06:04 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if you really wanted to swap gears you would be alright with 3.73's if you don't tow anything.
Old December 29th, 2010, 06:25 PM   #3
MilwaukeeF350
Dan
You would be better with 3.55
3.42 is little too much you would need cruise 90 mph to get rpm 2500
3.55 is perfect.
Old December 29th, 2010, 09:12 PM   #4
JoshG
At 70mph I'd like to be around 1900 rpm. Milwaukee, is there an option to get 3.55 into my 1998 3/4 4x4 Chevy Suburban?
Oh, and I don't really ever tow anything of any significance. If I did I would just leave it in 3rd gear.
Old December 29th, 2010, 09:38 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
gm never made a 3.55 gear. 3.42 or 3.73 are the closest things. with a 3.42 you would be at 1900 but your gonna spend almost a grand on 2 axles with a 3.42 gear. they did offer them but it was sorta rare on a 3/4 ton 4x4 to get that low of a gear. unfortunatly gm never offered a 3.42 gear in the suburbans. only the pickups. i'm not 100% sure they interchange.
Old December 30th, 2010, 01:05 PM   #6
JoshG
Kodiak, I have found some 3.42 front ends between $200-400 and I could change the ring and pinion on the rear end to get the right gear (with a little help from some friends)...but the front ends all say for 6 lug trucks.
I'm assuming that means they are not compatable with my 8 lug...anyone know for sure?
I had never heard of 3.55...I believe Dodge has that gear ratio.
Old January 14th, 2011, 06:18 PM   #7
Ebrown
Ebrown's Avatar
My blazer 1986 came with 3.42, 700r4, N/A 6.2, 31X10.50X15. It sucked ass pulling a 2 place trailer and 2 sleds at max I could hit was 50MPH with 850 degrees exhaust temp ( max for the 6.2 engine is 1100-1200 degrees ) now I have 3.73 and 31X10.50X15 and hit 65 MPH and about 650 degrees with same trailer and sleds!
Next phaze will be adding a banks turbo and 2 stage Methanol injection
Chevy used with there diesel engine ( n/a 6.2, T 6.2, n/a 6.5, T 6.5
3:08, 3:42 fuel milage and 3:73, 4:10 for towing
Ebrown is offline   Reply With Quote
Page generated in 0.27330 seconds with 44 queries
