Spider Gear questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 28th, 2010, 10:02 PM   #1
Joxracing
Joxracing's Avatar
Default Spider Gear questions
Im going to look at a 79 bronco tmrw, and the guy says the 2 front spider gears are broke.
Im real green on axle tech, i do more long travel 2wd stuff.
So how hard are these to fix?
How expensive?
The axle must be a Dana 44 or Dana 60 if its on the front of a 79 Bronco.
Any info greatly appreciated.
Thanks!
Joxracing is offline   Reply With Quote
Old December 28th, 2010, 10:07 PM   #2
rangerluc
rangerluc's Avatar
you can get a new set of spiders for 100 or less, and they are very simple to replace. just need to pull out the axle shafts, pull the carrier, pop out the cross pin and install the new ones
rangerluc is offline   Reply With Quote
Old December 28th, 2010, 11:34 PM   #3
don4life
don4life's Avatar
yah spider gears are real easy if u have any mechanical experience at all
don4life is offline   Reply With Quote
Old December 28th, 2010, 11:51 PM   #4
Joxracing
Joxracing's Avatar
thanks, thats what i like to hear.
Old December 28th, 2010, 11:58 PM   #5
rangerluc
rangerluc's Avatar
orrrr you could just replace said spider gears with a locker
Old December 29th, 2010, 12:12 AM   #6
Joxracing
Joxracing's Avatar
dumb question, but.
how much do lockers run for these?
is it dumb to run one up front, and none in the rear?
Old December 29th, 2010, 12:31 AM   #7
rangerluc
rangerluc's Avatar
Originally Posted by Joxracing View Post
dumb question, but.
its got locking hubs right? itd be nice to get one for the real as well. but im guessing around 300-375 for an aussie
Old January 10th, 2011, 06:53 AM   #8
littletrucker
I'd hit that
littletrucker's Avatar
you can get a new lockright (lunchbox locker.. replaces just spider gears) for about 250 bucks, you really wouldnt be able to tell its there untill you put it in 4wd- it would steer fine in 2wd- they dont lock up till power is applied to that axle
Old January 10th, 2011, 07:13 AM   #9
Flexin' XJ
Flexin' XJ's Avatar
Do you really need to pull the carrier? Can't you just rotate the carrier and push the pin out the front and the replace the gears? I'm just asking, I have never worked on a Ford axle.
Flexin' XJ is offline   Reply With Quote
Old January 10th, 2011, 07:21 AM   #10
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Depends on the gear ratio mostly, the lower gears are thicker and will have to pull them to get the pin out. But if it is stock and most likely 3:54 no you do not have to pull the carrier.
Page generated in 0.32443 seconds with 53 queries
