87 yota truggy-(UPDATE!!) front dovetail! - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 8th, 2012, 09:35 AM   #81
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Looks good.
Any thoughts on getting a little weight over the rear axle to balance it better?
What front springs are you running?
Old June 8th, 2012, 08:26 PM   #82
generalyota
Ridge Runners Offroad
generalyota's Avatar
yeah, im mounting a second propane tank at the very back. the fronts are stock 84's with trail gear 4" shackles.
generalyota is offline   Reply With Quote
Old June 10th, 2012, 08:25 PM   #83
generalyota
she got some spray on bedliner applied. 2 of the brake lines made. 2 more to make, then to charge the shocks. Almost ready!!!
Old June 13th, 2012, 07:04 AM   #84
KennyOffroad
KennyOffroad's Avatar
Looking Good
Old June 17th, 2012, 11:18 PM   #85
generalyota
got it sanded down and hit with some bedliner. plummed the rear brakes. i need to charge the shocks and make one more brake line and she'll be ready for a shakedown run.
Old June 23rd, 2012, 10:43 PM   #86
generalyota
well got the brakes plumbed and sealed(hopefully). i need to bleed em and charge the shocks tomorrow, then hopefully a shakedown run
my son wanted to wash the truck ie, play with the hose.
Old June 23rd, 2012, 10:48 PM   #87
generalyota
sittin' pretty!
Old June 24th, 2012, 10:42 AM   #88
KennyOffroad
Looking Nice!
Old July 12th, 2012, 01:06 PM   #89
generalyota
Well I haven't been able to wheel it yet. One of the shocks is leaking at the shaft and the reservoir can. I called FOA and they are supposed to be sending me another shock. Hopefully this doesn't take over 2 months to get it this time
Old July 18th, 2012, 12:50 PM   #90
generalyota
New shock arrived!!!! Now to get it mounted.
Old July 22nd, 2012, 09:54 PM   #91
generalyota
lowered the coilovers so now it doesn't sit like a dragster. took it out on it's maiden voyage. the rear flexes and rides amazing!
over extended the front end and pulled the driveshaft. A hilift and a winch and we were back riding in no time.
Old July 23rd, 2012, 07:37 PM   #92
generalyota
after much searching for reservoir mounts for my coil overs, I decided to make some. The trick billet one's from kartech at 40.00 a pop. I also didn't want to spend 30 dollars for 4 hose clamps and 4 small pieces of urethane. So I started looking around at work and found exhaust clamps for an Audi A6 are 2.14" in diameter. I removed the clamps from the tube a little grinding and they fit perfect. Welded them to the cage. bolted them down and they work great!
I'll post the part numbers if anyone is interested.
Old July 25th, 2012, 07:38 AM   #93
generalyota
Added some tubes for bracing the shocks.
Old July 25th, 2012, 10:47 PM   #94
generalyota
Old July 27th, 2012, 03:30 PM   #95
KennyOffroad
Looks Ready to wheel
Old July 27th, 2012, 10:53 PM   #96
generalyota
fa sho 100%!!!
...when?...
Old July 27th, 2012, 11:21 PM   #97
KennyOffroad
Pm sent
Old July 28th, 2012, 11:13 PM   #98
generalyota
took it out for some hardcore wheeling. this thing is a beast. very happy with the rear suspension!
Old July 29th, 2012, 12:14 PM   #99
generalyota
here is a vid of the last hill.
https://www.youtube.com/watch?v=0BMI...e_gdata_player
Old July 31st, 2012, 08:41 AM   #100
KennyOffroad
Testing was Good !
Page generated in 0.52263 seconds with 83 queries
