87 yota truggy-(UPDATE!!) front dovetail! - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 2nd, 2013, 10:15 AM   #181
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Originally Posted by generalyota View Post
I've come to the realisation that it will never be done. Just different stages of operation.
I understand
Old January 2nd, 2013, 10:39 PM   #182
generalyota
generalyota's Avatar
got the other side done.
mounted the coil and power steering reservoir.
it's sloooooowly turning into a buggy.
generalyota is offline   Reply With Quote
Old January 3rd, 2013, 08:22 PM   #183
KennyOffroad
Take the cab out and start building the 4 seater setup.
Old January 3rd, 2013, 10:56 PM   #184
generalyota
once i get my bender and notcher. im just now in the idea/logistics stage.
Old January 6th, 2013, 07:06 AM   #185
generalyota
got the propane regulator mounted, fuse box mounted, and got it running last night. Today's goal is to get the wiring taped back up and secured. Then front drive shaft and put the doors back on, oh and trim the hood.
Old January 6th, 2013, 09:00 AM   #186
ssgtgaines
ssgtgaines's Avatar
Sweet!
ssgtgaines is offline   Reply With Quote
Old January 6th, 2013, 12:56 PM   #187
KennyOffroad
Nice work
Old January 6th, 2013, 06:21 PM   #188
generalyota
finished the wiring and trimmed the hood. I need to find a spot to mount the winch solenoid box.
Old January 6th, 2013, 06:40 PM   #189
chevotass
chevotass's Avatar
i dig it
Old January 7th, 2013, 06:35 PM   #190
KennyOffroad
Looking Good Matt !
Old January 15th, 2013, 08:00 AM   #191
generalyota
got a full floater 14 bolt for the rear!
Old January 15th, 2013, 08:05 AM   #192
generalyota
Now I have to decide if I want a GM dana 60 or build a steering 14 bolt. I'm kinda leaning towards a 14b just for the strength, and alittle for the cool factor.
Old January 15th, 2013, 08:55 AM   #193
Wramblerguy
Wramblerguy's Avatar
I vote 14b
Idk how much shafts are but it probably wouldn't be much more $ to build
3rd generation jeeper
Old January 15th, 2013, 09:32 AM   #194
ssgtgaines
ssgtgaines's Avatar
14 bolt is gonna be crazy expensive. But i agree it would be cool.
Old January 15th, 2013, 11:02 AM   #195
Wramblerguy
It can't be that much
Idk I haven't priced out a set of shafts for it
But you could probably build the housing for like 3-500 Bucks
Old January 15th, 2013, 11:05 AM   #196
Bruster
I have a dodge d61front forsale for 500 $
Old January 15th, 2013, 08:51 PM   #197
generalyota
driver or passenger drop. manual hubs?
Old January 15th, 2013, 09:07 PM   #198
ssgtgaines
ssgtgaines's Avatar
if its a 61 i dont think you want it.
Old January 15th, 2013, 09:35 PM   #199
Wramblerguy
if this canadian can do it, so can you
Old January 16th, 2013, 03:34 AM   #200
Bruster
Pass and manual hubs..
Yes its a 61 and yes it can be geared low..yes you can use dana 60 ring gear parts..yes its the same spline axles as a 60..has slightly larger axle tubes also.
Need a 4.56 carrier and a thick ring gear set and its do able..go check out pirate and youll see sstgaines
Page generated in 0.52583 seconds with 83 queries
