Indash single din dvd player - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 25th, 2010, 10:58 AM   #1
badmag71
badmag71's Avatar
Default Indash single din dvd player
have a really nice vr3 indash dvd player for sale,works great,only reason im getting rid of it is i bought a double din dvd player,comes with remote, asking 125.00 heres the specs of it
VR3 brings media solutions to your car. This In-Dash DVD player brings your videos to life right in your car. There is no need for extensive modification to your car to have full DVD capabilities. All you need is an available DIN slot in your car and you are ready to experience music and videos on the road.
A Plethora of Video Inputs/Outputs
The VRVD630 gives you a variety of inputs and outputs to customize your DVD experience. You can connect an Auxiliary video or audio source such as a PS2, Satellite Radio, iPod, or any other source. The supplied cable allows you to connect a video source through a 3.5mm jack. You can use the Dual RCA to Mini Male Stereo Adapter to connect the audio sources and the Planet Waves Mini-Stereo to RCA Adapter to connect the video source. If your source uses a mini-stereo out, then you can connect the source directly.
Another way to view video is the USB and the SD Card slots. You can watch MPEG4 and DIVX files right from the USB flash drive or SD card. The DVD Deck is compatible with both NTSC and PAL sources so you have a broader choice of video to choose from. The device reads ID3 tags to display information about each song. You can easily select the songs you want to listen to and enjoy the on-screen display to easily view the upcoming songs.
MP3/WMA Playback
You can play MP3's or WMA from CD's, DVD's, USB, or SD. Although the VRVD630 can play a variety of files, it won't play mixed content on discs or the flash drives. It will play either all MP3, DIVX, or MPEG4 files from the selected source.
Audiophile Quality
The VRVD630 offers great sound features that will blow your socks off. The onboard amp supplies 180 watts of raw power. If that's not enough for you then you can use the two pairs of pre-amp outputs to connect to external amplifiers for increased audio response. To further pound out your rockin' jams, you can use the sub-woofer out signal to control a subwoofer directly from the deck. This provides you with five channels to control your surround sound system. If you have digital receivers, the VRVD630 can use the RCA outs as SPDIF digital outputs to supply your speakers with pure and clear sounds.
Easy To Use
The VRVS630 is easy for anyone to use. The supplied remote gives you access to multiple options and features to better control your DVD deck. The deck itself is comes in the standard single DIN size and is easy to install and universal for any car, truck, van, or boat. You won’t be disappointed with the VR3 VRVD630.
ID:	72262   Click image for larger version
Name:	DSC02560 (539 x 404).jpg
ID:	72263   Click image for larger version
Name:	DSC02561 (539 x 404).jpg
ID:	72264   Click image for larger version
badmag71 is offline   Reply With Quote
Old January 15th, 2011, 04:33 PM   #2
newdodge
jeep life
newdodge's Avatar
i would trade for a hole system 10 12 and amp with cd player
newdodge is offline   Reply With Quote
Old January 15th, 2011, 04:48 PM   #3
badmag71
badmag71's Avatar
pm me some specs
Old January 19th, 2011, 03:51 PM   #4
badmag71
badmag71's Avatar
Will trade also
Old January 23rd, 2011, 03:09 PM   #5
badmag71
badmag71's Avatar
Bump
Page generated in 0.29253 seconds with 39 queries
