The Eliminator - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2012, 06:31 PM   #21
Lousypirate
Whoop Whoop
Lousypirate's Avatar
In the photos above:
Rear end was bobbed, have an 80+ degree departure angle now. Cut the frame behind the DIY shackle flip mounts and welded a rectangular heavy wall tube in it's place. then welded some 3/4" plate for clevis tabs (overkill, but found them in the scrap bin, just needed some trimming).
Doubler kit is well under way, NP203 is mounted, new crossmember fabricated. waiting on np205 to come back from machine shop early this week. Then rebuild that, check to make sure my twin stick works, and install. Get my exact driveshaft lengths figured out and start mocking up the shifters.
Side step/rock sliders welded up, about the same width as the widest part of the cab sides.
electric fan wired up, sucks harder than a dyson. just running a switched relay. I didn't want to mess with the themostat on it quite yet.
5 point harnesses redneck welded in for temporary use... will get relocated when I decide to make a cage and get rid of the bench seat.
wheel spacers installed to get the track width right front and rear.
taillight brackets made and wired. looks goofy right now but thinking forward to when I do the flat bed/roll bar in the bed.
rear end got a solid diff cover, lubelocker, and a lock right locker.
Things to get done before Dec 11:
- fluids
- fix leak in holley carb... maybe it's the fuel line. I didn't check that hard.
- install np205
- triple stick
- driveshafts
- redo exhaust (ordered mufflers from jegs today)
Old October 31st, 2012, 11:55 PM   #22
Lousypirate
Whoop Whoop
Built up the np205 tonight... Finally got back from machine shop. Mufflers came in, installing np205 on friday hopefully and knocking more off of the odds and ends list saturday morning.
Gonna have my dad shorten the rear shaft, and order up the rest of the stuff I need from mcmaster tonight yet. Still looking for front shaft.
Sent from my htc evo
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old November 3rd, 2012, 03:35 PM   #23
Lousypirate
Whoop Whoop
Got the np205 installed.
Ended up welding the shift linkage rod to the adapter, and held the sleeves on with two welded sae nuts. Used 3/8 tips ends and made sleeves that go over the shift rails.
Material will be in on monday for the shift levers, with secret for the shift knobs.
Other than that just measured up driveshafts.
ID:	98236   Click image for larger version
ID:	98237   Click image for larger version
Mary Jane (46 CJ2a)
Old November 6th, 2012, 07:46 PM   #24
Lousypirate
Whoop Whoop
Sneak preview of the shift lever "knobs"
Mary Jane (46 CJ2a)
Old November 18th, 2012, 09:31 PM   #25
Lousypirate
Whoop Whoop
On the slate for this holiday weekend:
- weld shifters on to bushings
- glue the .50 cal shells on to shift levers after painting the bare metal
- assemble front driveshaft
- install front/rear driveshaft
- install toolbox on framerails
- fix fuel leak somewhere between filter and carb somewhere...
- oil change/top off all other fluids
- chase some wiring
- test drive to gas station to fill up
Anybody have an idea what glue or silicone will work best for gluing the .50 cal shells on with? I'm thinking of using silicone in a caulk gun. Worried about the shift levers being/getting loose and not performing.
Old November 18th, 2012, 10:36 PM   #26
Dirthog250r
FORD POWER!!!!!!!!!!!!!!!
Dirthog250r's Avatar
Use j-b weld
Dirthog250r is offline   Reply With Quote
Old November 18th, 2012, 11:17 PM   #27
moparhorse
moparhorse's Avatar
What he says. Use jb weld inside the shells then push the shells on. Maybe make the top of the shifter rough where the jb weld will adhere to.
You never know what will happen in copemish, lol
moparhorse is offline   Reply With Quote
Old November 19th, 2012, 09:09 AM   #28
Lousypirate
Whoop Whoop
Originally Posted by Dirthog250r View Post
Use j-b weld
JB didn't cross my mind. I was planning on roughing up the surfaces for better adhesion prior anyways. Thanks!
Old November 25th, 2012, 08:49 PM   #29
Lousypirate
Whoop Whoop
Finally drove it out of the shop. Needs front driveshaft, some fluids, two leaks repaired, and exhaust... mounds trip Dec 9.
Maybe some tab renewal too... gotta bribe someone for a trailer as well.
Locker is quite nice. Does burnouts with 37s too.
ID:	98859   Click image for larger version
Mary Jane (46 CJ2a)
Old December 7th, 2012, 04:04 PM   #30
Lousypirate
Whoop Whoop
Exhaust is done on one side. really happy with the results. Going to do the other side before christmas
Front driveshaft didn't work out. Need to go back to a CV style.
Carb plugged up. She's old so I'm just not going wheeling this weekend. Going to take the excuse to further better the rig. Motor will be pulled and rebuilt, going to swap to an aluminum fuel cell this winter. probably fund most of that part with tax return money...
looking for some new heads (56cc 305 heads aren't exactly great on a 400)
Truck avenger carb
new crank to fix main seal leak
different cam for more torque.
I'll post pictures of the exhaust next time I'm near the truck. comes out by crossmember mount then tucks up where gas tank used to be and dumps above rock slider bracket with a turnout. Jegs flowmaster type muffler. Got about $90 into the passenger side. Might be more like $100 on driver side because of different routing strategy.
Old June 4th, 2013, 10:04 PM   #31
Lousypirate
Whoop Whoop
Motor build is coming along nicely.
Propane 412 sbc.
Mary Jane (46 CJ2a)
Old August 3rd, 2013, 03:19 PM   #32
Lousypirate
Whoop Whoop
Baby steps
The yellow tank mount was free, however is it pretty bashed up so will be replaced with a less chinky or new one down the road.
Forgot some stuff at home last night, so didn't get to make more progress... drive my dad around all morning too so I didn't get a good start on it. Oh well.
I96 tonight for some Sprint cars. Yeah buddy
Mary Jane (46 CJ2a)
Old September 7th, 2013, 11:56 PM   #33
Lousypirate
Whoop Whoop
Getting closer, still a lot of little things to do. I kind of wish it was up at my house in the garage right now instead of being 45 minutes away.
Mary Jane (46 CJ2a)
Old November 13th, 2013, 11:40 AM   #34
Lousypirate
Whoop Whoop
getting the itch to do some fab work... thinking about picking up a kinker and trying my hand on a rear cage... with the ability to become a full exo down the road. I like headroom.
Haven't touched it since I plunked the motor in. Need to finish bolting everything up, and get the propane ran.
Anybody run these without the inner fenders? I'm contemplating ripping mine out.
Mary Jane (46 CJ2a)
Old November 13th, 2013, 12:47 PM   #35
firehawk
Live Action!
firehawk's Avatar
Didn't even know you had a rig haha
Old November 13th, 2013, 12:51 PM   #36
Lousypirate
Whoop Whoop
I got two, well, the wife has one, and I have one. Check the Sig lol
Mary Jane (46 CJ2a)
Old November 13th, 2013, 01:25 PM   #37
redhead_823
redhead_823's Avatar
Does it even run?
redhead_823 is offline   Reply With Quote
Old November 13th, 2013, 01:54 PM   #38
Lousypirate
Whoop Whoop
Originally Posted by redhead_823 View Post
Does it even run?
Haven't gotten that far yet...
Gotta get some wrenching done to get it back together first
Mary Jane (46 CJ2a)
Old November 13th, 2013, 02:10 PM   #39
Lousypirate
Whoop Whoop
I did doodle this today
Mary Jane (46 CJ2a)
Old November 13th, 2013, 05:50 PM   #40
firehawk
Live Action!
firehawk's Avatar
Stop slackin ya doodler!
Page generated in 0.33947 seconds with 84 queries
