84 ranger ignition switch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2010, 01:03 PM   #1
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
Default 84 ranger ignition switch
Where is the ignition switch located on an 84 Ranger 2.8 liter? So far all ive found is the headlight switch. Thanks.
84mudder is offline   Reply With Quote
Old December 21st, 2010, 01:35 PM   #2
kevinr839
kevinr839's Avatar
Copied form mitchell on demand
Removal
1. Rotate key to "lock"position. Disconnect battery ground. On tilt columns, remove upper extension shroud by squeezing at the 6 and 10 o"clock positions and popping free of the retaining plate at the 3 o"clock position.
2. Remove 2 shroud halves by removing the 2 attaching screws. On all models, disconnect electrical connector from ignition switch. Drill out the 2 break-off head bolts holding the ignition switch to the lock cylinder with a 1/8" drill bit.
3. using an easy- out, remove bolts. Disengage the ignition switch from the actuator pin and remove switch.
Installation
1. Rotate ignition key to the run position. Install switch by aligning the holes on the switch casting base with the holes in the lock cylinder housing. Minor movement of the lock cylinder to align the actuator pin with slot in switch carrier may be required.
2. Install the new break-off head bolts and tighten until heads shear off. Connect the electrical connector to the ignition switch. To complete installation reverse removal procedure.
kevinr839 is offline   Reply With Quote
Old December 23rd, 2010, 12:55 PM   #3
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
Here's a breakdown of the column. Ignition switch is highlighted.
Troll53 is offline   Reply With Quote
Old December 24th, 2010, 05:31 PM   #4
84mudder
84mudder's Avatar
thnx for the pic.
Page generated in 0.17530 seconds with 35 queries
