electrical/charging problem? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 19th, 2010, 01:33 PM   #1
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
Default electrical/charging problem?
84 Ranger with a 302 carb v8. Brand new alternator, battery, cables, and push button starter switch. The truck will fire right up in the cold. Let it warm up fully and shut it off. Go to start it and it acts as if the battery is very low on juice. It will hardly have enough cranking amps to turn the engine over...but let it sit overnight then go to start it next day it will fire right up and the engine turns over at a good pace. What could be wrong?
84mudder is offline   Reply With Quote
Old December 19th, 2010, 03:03 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
heat.
something is expanding after it warms up. most likely a bad connection at the block. I would say its not unlikely you have a corroded joint or loose greasy joint that is opening up after it warms. also painted surfaces don't carry current, scrape them to clean metal where ever a cable connects. if you have any use star washers that dig into the connection to guarantee its stability
Yetti
Old December 19th, 2010, 07:18 PM   #3
84mudder
84mudder's Avatar
Originally Posted by Yetti View Post
heat.
thx yetti. yeah turns out had an improper ground. Works like a charm now.
Page generated in 0.18132 seconds with 32 queries
