Sbf flex plates - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 16th, 2010, 07:35 AM   #1
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Question Sbf flex plates
So how do you find the part number on a used flex plate? I found some numbers on the weight but they are not the complete part number.
I am trying to mate a AOD to a 351w and got a flex plate that was suppose to be the right one but is the same as the plate that was on the motor which I believe was a E40D plate?
Old December 28th, 2010, 06:46 PM   #2
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
I think its a 89 Crown Vic w/351w and aod
OE # E0AZ-6375-A
164 teeth ; pitch 12
14.23" outside diameter.
part number FRA-205 at autozone $49.99
fordlovinfarmer is offline   Reply With Quote
Page generated in 0.13897 seconds with 29 queries
