60 Chromo shafts? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2010, 10:14 AM   #1
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Default 60 Chromo shafts?
Wheres the best place to get the 35 spline outters?
Need a set for my Ford 89 kingpin 60
Also whats lockouts to run?
Old December 15th, 2010, 10:33 AM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Buy Superior shafts and drive flanges, if you want hubs get dynaloc's. They don't make a hub that will take the abuse a Superior shaft will handle, except the pricey Dynatrac stuff.
Old December 15th, 2010, 10:42 AM   #3
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Who makes these
Old December 15th, 2010, 10:44 AM   #4
BigBlockBlazer
Axle breakin' 101
Not sure, but a that price they can't be that good and I'm guessing no warranty. The Superior are $131 and have a 10 year warranty.
Old December 15th, 2010, 10:49 AM   #5
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
According to the people on pirate, they are yukons. I plan on buying a set of my 60
I'm the man in White.
Old December 15th, 2010, 10:59 AM   #6
Originally Posted by Mr. Beefy View Post
Who makes these
I would rather get the Spicer D70 stubs then those. And yes JBG no-names are yukons.
Old December 15th, 2010, 11:00 AM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Ok.. Where do you get em?
Lookin for links people
Old December 15th, 2010, 11:19 AM   #8
35 Spline stub shafts (D70) Spicer part #: 3-82-871
I bought mine from weller, can find them on ebay all over though. They are not a direct fit in a ford hub though. Some modification is needed due to there length. I couldn't afford chromos in the spring and was tired of shattering 30 spline stockers. Been running these since maybe June/July. No issues, been really happy with them.
Old December 15th, 2010, 11:30 AM   #9
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Are they actually stronger than a regular 35 spline 60 shaft then?
Old December 15th, 2010, 11:38 AM   #10
Skooter_Built
not really they are just cheaper.
Old December 15th, 2010, 12:04 PM   #11
liv2mx
i like jungle gym's.
liv2mx's Avatar
call jimmy at extreme for 10 factory or yukons, extremeoffroadparts.com.or dale at ironmanoffroad. call machine wave listed on pirate and ask for scott for superiors. extreme also make very nice drive flanges with a grease zerk in them.200 for a set.
if your going to spend the money get superiors and be done.seen alot of broken 10 factory and yukons in the last 3 years.
Old December 15th, 2010, 12:43 PM   #12
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
If you are going to run your factory inners the stubs from Jeff's would be fine, but as said superiors and be done.
Lockouts either broached stock spicers or dynaloc if you have the cash, flanges will be cheaper and stronger though
Old December 15th, 2010, 12:51 PM   #13
liv2mx
liv2mx's Avatar
even if your just doing the outers get the good ones.... because you WILL replace the inners sometime.then you will have no worries once it is all done and will be cheaper in the long run then buying cheap, then breaking, then buying better stuff.
you plan on running 42's or 43's and i know how you drive..you need the good stuff.
get flanges, don't waist your money on lockouts.i saw 3 broken lockouts last weekend in about 2 hours.all 35 spline stuff.
Old December 15th, 2010, 12:56 PM   #14
Jeepaholic
Jeepaholic's Avatar
I agree but what happens when you take out the inner and destroy a $200 stub, I would be pissed.
But if he is running 42-43 he needs alloy inners and outers, I thought he was sticking with the 38's
Old December 15th, 2010, 01:03 PM   #15
liv2mx
liv2mx's Avatar
i have broke 4 stock inners.with superior outers.they usually break close to the pinion. if it did, you have superiors outers no worries..they are under warranty.
i did the outers first then the inners when i could afford them.i have all superiors now.
or drop 1900.00 once and get the rcv shafts and never worry again.
Old December 15th, 2010, 01:10 PM   #16
Jeepaholic
Jeepaholic's Avatar
RCV read they are making a bigger cv and 40 spline shafts
Old December 15th, 2010, 01:18 PM   #17
BigBlockBlazer
Axle breakin' 101
This is the best option, their 60 and Rockwell shafts use the same cv bells. Strong as f*ck.
Old December 15th, 2010, 01:20 PM   #18
liv2mx
liv2mx's Avatar
yep cameron has broke 3 in the last 4 months.so i guess they changed some stuff to make them even stronger.
Old December 15th, 2010, 01:20 PM   #19
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Ya... Umm no on the RCV's It took me 2 years to break the 44 shafts
Old December 15th, 2010, 01:22 PM   #20
liv2mx
liv2mx's Avatar
things will change alot now your running the big shoes. big tires and a v8 with your goofy ass behind it..things will go boom!!
Page generated in 0.27886 seconds with 83 queries
