pertronix ignition kit bbf - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 12th, 2010, 09:44 PM   #1
joshcorey56
Default pertronix ignition kit bbf
i was looking at a pertronix ignition system for 520$ or a msd ignition for 620$. the motor has aluminum blue thunder heads, comp .634 lift cam, roller rockers, roller cam bearings, srp flat top pistons, eagle h-beams. 460 victor intake. i was wondering what ignition would work good on this motor. i know msd is the best but is it worth it to spend an extra 100 bucks? thanks
joshcorey56 is offline   Reply With Quote
Old December 13th, 2010, 06:18 AM   #2
frdboy
frdboy's Avatar
Yes........I would run MSD over Pertonix any day but I do think MSD's quality has gone down hill over the years. You could also check out Mallory's stuff.
Old December 13th, 2010, 08:30 AM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
I personally wouldn't run the MSD if you want reliability, my 6AL CDI box would overheat all the time and quite working at completly random intervals.
I figured it was just a bad unit, so i bought a new one, same problems with that one as well.
I'm not sure if others have had the same problem with theirs, just my own expierence with it.
I have no expierence with the other system.
Old December 13th, 2010, 08:37 AM   #4
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Why not just run D.U.I at half the price? Then add a Summit MSD box later if you need more juice. I've run the stock Chevy HEI on my BB with a Summit box for two years with zero problems. It's been through every temp extreme, from idle all day to looong full throttle assaults at the dunes and Dog Party.
Old December 13th, 2010, 08:38 AM   #5
joshcorey56
ok. thanks guys. my brothers got msd 6al in the big jeep and it works. i guess its just personal preference then huh. ill check out mallory to.
Old December 13th, 2010, 08:45 AM   #6
frdboy
frdboy's Avatar
Yeah, I have run MSD stuff for the last 15 yrs and never had an issue. I think alot of failures are installation/wiring issues.
Page generated in 0.18726 seconds with 41 queries
