*****MTY Mouse XJ Build***** - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2010, 11:25 AM   #21
MTY Mouse
MTY Mouse's Avatar
So, I wheeled some more
and then made the mistake of going to twisted trails,
now I was hooked, everything had to be bigger, locked, and better. SO I picked up a 8.8/D30 combo with 4.56 gears locked in the front and spool in the rear,
problem was the locker in the front had the springs and pins in backwards and broken. The spool in the rear was broken as well.... so I fixed the locker issues and then went to limited slip in the rear. Orginal 8.8 I bought was all set up for a TJ so I sold that housing and got a bare one, then added UBE.
Now that I got the right gear and a little better axles it time for some new meats.
35x12.5x15,SSR's and had to go with wider rims also.....
Added some ACOS in the front to level it out after the 1.5" UBE added some height in the rear. This is how it turned out!
Action Photo from blessing
ppkaprince98 helped a ton getting MTY Mouse to the point you see it in the above pics. Seemed like he and I were together every weekend changing stuff on his or my rig. Or we were wheeling the shit out of them, had a blast.!!! AND A FEW COCKTAILS ALONG THE WAY!!!
Not sure this is normal build thread info, but alot of times it is all about the time you get to spend with your buddies, family members, and your kids that makes this worth all the time, effort, and expense................. SO I WOULD LIKE TO TAKE THE TIME TO DEDICATE THIS BUILD THREAD TO THOSE THAT HELPED ME OUT AND GIVE YOU THE OPERTUNITY TO CHECK OUT A COUPLE OF THEIR RIGS......
PPKAPRINCE98, He no longer has this Jeep because things got a little complicated and he has not been able to wheel for a year or two now, but he will be back!!!! Thanks for all the help on MTY Mouse!!
rockstarryan and one of the jeeps he used to have....
My Dad and Father in Law also helped a ton!!!! Thanks Guys!!!!!!
to be continued............ up next rock rails and bumper build up!!
MTY Mouse is offline   Reply With Quote
Old December 18th, 2010, 01:18 PM   #22
Modestmar00Xj
Show me the trails!
Modestmar00Xj's Avatar
Send a message via AIM to Modestmar00Xj Send a message via Skype™ to Modestmar00Xj
good work man! your jeep is really nice! how do you like your rear 8.8? im torn between doing an 8.8 or just doing the d60!
Modestmar00Xj is offline   Reply With Quote
Old December 18th, 2010, 02:33 PM   #23
MTY Mouse
MTY Mouse's Avatar
8.8 is out and sold, it did work great for me and keeps things simple because of bolt pattern and all, almost caught up to where the jeep sits now (Jack Stands) I will be putting in 60's this winter/spring, always go big!!!! Learn from the guys like me, who do it three times. I guess it all depends what your ultimate goal is, A wiseman once told me, make a plan and no matter how long it takes stick to it, just tell yourself the end result will be worth the wait
Old December 18th, 2010, 03:08 PM   #24
Cool parts peddler
Ironman Offroad's Avatar
And on to phase 3!
Nice thread.
Old December 18th, 2010, 03:32 PM   #25
MTY Mouse
MTY Mouse's Avatar
So now that I was starting to hit parks and bigger obstacles, it was time for some protection. Old man always told me that was important
Got a couple 2"x4"'s, some 1"x3", and some 1"x1" angle iron. Started to go to work....
Mock up
Capped the ends
Paint
Hardware and mouting (drilled and tapped the framerail)
Finshed Product
I do use them, probably more then I should (see avatar), the 1x3's should have been thicker... I should have also added one more outrigger to the framerail. they did bend a bit in the front and rear after a few hard hits, all in all-other then the locker, these are the best add on that I have on the XJ!!! if you build some of these overkill is advised going to have to cut the rockers out this winter..
Old December 19th, 2010, 10:28 AM   #26
rockstarryan
rockstarryan's Avatar
Thumbs up some more stuff!
hopefully you will enjoy these videos!
this one is Adam getting hung up on some tires!
This one is the long crawl at Rocks & Valleys...and us making fun of Adam for not listening to our spotting!! We still love ya buddy!
rockstarryan is offline   Reply With Quote
Old December 19th, 2010, 10:57 AM   #27
isuzutruggy?
Kreepy Krawlerz Off Road
isuzutruggy?'s Avatar
awesome job on those flares
isuzutruggy? is offline   Reply With Quote
Old December 19th, 2010, 05:53 PM   #28
89xjr
sommertyme 4x4
89xjr's Avatar
sweet rig
89xjr is offline   Reply With Quote
Old December 19th, 2010, 07:15 PM   #29
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
I sure hope the rest of this build goes this fast...
NitzPixs is offline   Reply With Quote
Old December 19th, 2010, 09:32 PM   #30
MTY Mouse
MTY Mouse's Avatar
That is what I keep thinking, going to get this caught up and then it is going to really, I mean really slow down.......
Well lets keep it going.
ppkaprince98 hooked up with Clint357 and let him use his sandblaster on a bumper he had just built, he told Chris that he had some steel to put together another XJ bumper, So agian I should give a majority of the credit to others, Clint designed and had the peices cut and built a few bumpers for people, this time he just sold me the pieces and gave me some simple drawings to help put the stack of steel together, work out good, plus gave me a change to work on my welding skills, as you will see not the best, please keep comments to a minimum... This was around April 2010
Pulled the other bumper off.
Started with mocking up the frame attachments
And more puzzle to put together..
Weld time... Need to build a table
Clint did a great job thinking this out, sorry my welds make it look worse then it should.
To protect it, I decided to have it sand blasted and Line X'd. Turned out really cool!!!
Old December 20th, 2010, 09:07 AM   #31
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
That Jeep has come a looooong way. Its been lots of fun building it, there is a lot of good memories in this thread. But all kidding aside, its time to go big and get nasty with it.
Old December 21st, 2010, 06:35 AM   #32
John D
John D's Avatar
You are going to love this when you get it done. I think it looks a million times better too. I know people do what they have to do based on what they have available, but I hate the look of the sliders hanging down.
Nice build, my first XJ was a red '91 Laredo with chrome everything.
Old December 21st, 2010, 07:01 AM   #33
kmas
kmas's Avatar
nice build!
kmas is offline   Reply With Quote
Old December 21st, 2010, 01:07 PM   #34
MTY Mouse
MTY Mouse's Avatar
Thanks for the comments!!!
John, see you Friday morning.
Old December 21st, 2010, 03:43 PM   #35
John D
John D's Avatar
If you have time Friday I'll show you my rig.
Old December 21st, 2010, 05:34 PM   #36
branch92
Only in a jeep
branch92's Avatar
nice rig workin on doin a xj myself
branch92 is offline   Reply With Quote
Old December 21st, 2010, 05:44 PM   #37
99_JeepGC
It's a jeep GIRL thing!
99_JeepGC's Avatar
Send a message via AIM to 99_JeepGC
nice build! turned out really good.
99_JeepGC is offline   Reply With Quote
Old December 21st, 2010, 06:11 PM   #38
MTY Mouse
MTY Mouse's Avatar
Cool, I need to drop off a uhaul trailer in Rockford(killing couple birds with one stone), I should be able to make time. I am interested in checking out the TNT truss, I am thinking that is the route I am going to go with my front D60. I will probally try and get over your way early on Friday morning, have coffee ready
Old December 21st, 2010, 06:44 PM   #39
John D
John D's Avatar
Early Friday morning I will be on to diet Mt Dew, unless your coming at 06:00 :D
Sent you a PM.
Old February 5th, 2011, 12:39 PM   #40
MTY Mouse
MTY Mouse's Avatar
Dislocated my shoulder right after x-mas so making things even slower....
Pulled the whole bottom out of it. Here is how it sits now!!!
Sold All this Stuff!!!! (except for the 60 on the bench)
**Note: My daughters barbie jeep build hanging on wall! Another half done project
Got my ube's in the mail Friday for the rear, got tracking numbers on the front truss and inner fender eliminators from TNT. Will be getting pics up when they show up.
Picked these up too!!! (Bling!!!)
Page generated in 0.52744 seconds with 85 queries
