axle swaps. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 11th, 2010, 12:58 PM   #1
1985fordman
Default axle swaps.
i got a dana 44 and gm 14 bolt im puttin under my 85 ford. can anyone give me advice on the steering linkage?
1985fordman is offline   Reply With Quote
Old December 11th, 2010, 01:02 PM   #2
kj kyle
kj kyle's Avatar
throw that dana 44 steering arm in the garbage, and run cross over steering.
kj kyle is offline   Reply With Quote
Old December 12th, 2010, 06:37 PM   #3
1985fordman
do you know much about the scissor axle that comes stock? im thinking that the steering setup will work out with the stock setup if i take it off the scissor axle and put it on the straight axle. preciate the help man. get back to me if ya can
Old December 15th, 2010, 09:25 AM   #4
Quiefinator
go'til itsounds expensive
Scissor Axle? Are you talking about the TTB ( twin torsion beam)?
Old December 15th, 2010, 09:28 AM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
twin traction beam
...and no i would not run the steering setup off a ttb truck on a solid axle.
Old December 30th, 2010, 06:20 PM   #6
1985fordman
yea i have figured out alot while i have been workin on it. its all comin together good. i have to make a longer trac bar, the steering setup is the solid axle setup. i have some DOM tubing and i have to make the steering arm shorter because the steering setup on my 85 the gearbox is on the inside of the frame and on the 78(what the solid axle came off of) the box is on the outside of the frame. im put some pictures up in a few days when i get it all done. puttin the 4.10 gears in the rearend tomorra.(the front already has them) and i will probably get it finished up this weekend! preciate all yals help!
Page generated in 0.25534 seconds with 41 queries
