obd1 codes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2010, 08:29 AM   #1
95yukongt
95yukongt's Avatar
Default obd1 codes
Does anyone have a list the the code for obd1. My 95 Yukon has code 54. It doesn't run bad but it drop 2mpg since it thew the code.
95yukongt is offline   Reply With Quote
Old December 8th, 2010, 10:40 AM   #2
IFS SUCKS
I like trees
IFS SUCKS's Avatar
DTC 54 - Fuel Pump Relay Circuit (Low Voltage)
RESULTS OF INCORRECT FUEL PUMP RELAY OPERATION
* An inoperative fuel pump relay can result in long cranking times, particularly if the engine is cold. As a backup system to the fuel pump relay, the fuel pump is also turned "ON" by an oil pressure switch. The oil pressure switch will turn "ON" the fuel pump as soon as oil pressure reaches about 28 kPa (4 psi).
IFS SUCKS is offline   Reply With Quote
Old December 8th, 2010, 03:02 PM   #3
95yukongt
95yukongt's Avatar
thank you.
Old December 8th, 2010, 03:03 PM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
I haven't delt with OBDI stuff in forever. I don't miss that shit especially with non-GM cars.
Old December 8th, 2010, 09:08 PM   #5
95yukongt
95yukongt's Avatar
I don't mind obd1 because i can check the code without a scantool
Old December 9th, 2010, 03:32 PM   #6
IFS SUCKS
I like trees
IFS SUCKS's Avatar
No problem,and yes OBD1 sucks .
Page generated in 0.25982 seconds with 41 queries
