vintage sled track issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2010, 09:35 PM   #1
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
Default vintage sled track issue
Ive got a 76 scorpion range whip. It has a 119" track only problem is i cant find any. Will another track fit? or am i screwed?
scare-crow is offline   Reply With Quote
Old December 8th, 2010, 10:44 AM   #2
distant75
distant75's Avatar
It might be worth a try.
http://tracksusa.com/
The baddest mini Jeep around
www.banishedcreations.com Yes its a work in progress.
distant75 is offline   Reply With Quote
Old December 8th, 2010, 10:49 AM   #3
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
try this place
http://www.sledtrack.com/
NitzPixs is offline   Reply With Quote
Old December 9th, 2010, 03:15 PM   #4
scare-crow
the eskimo bro
scare-crow's Avatar
How hard would it be to swap in suspension from a polaris?
Old December 9th, 2010, 03:44 PM   #5
bigblocked
bigblocked's Avatar
Kimpex makes a 119" track.
bigblocked is offline   Reply With Quote
Old December 9th, 2010, 03:46 PM   #6
FlamingTomato
You break it - You fix it
FlamingTomato's Avatar
since swapping the skid kills the originality of the sled - you might be better off selling yours and putting that $$ towards a newer sled. They are all over CL for the 800-1200 range.
On a side note - was that around the time Arctic Cat was buying them out - you may want to look at El Tigre' track sizes.
FlamingTomato is offline   Reply With Quote
Old December 9th, 2010, 04:02 PM   #7
scare-crow
the eskimo bro
scare-crow's Avatar
yes i think Cat bought them out a year later. I'll check into that.
Old December 9th, 2010, 04:36 PM   #8
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I know most of the Scorpion tracks are very narrow as compared to the old AC machines. also the majority of AC's had the 3 piece tracks with steel grouser bars
Yetti
Old December 9th, 2010, 04:40 PM   #9
Yetti
Yetti's Avatar
haven't seen it done in a while since most of the old stuff is gone, but you can up grade your chassis by adding a late model suspension to the old sled. the thing is to find a track and cradle set up that matches the drive width of the tunnel and the front out put shaft. you can add loads of suspension by doing it but its a bit tricky to get all the angles right.
Yetti
Old December 9th, 2010, 05:03 PM   #10
scare-crow
the eskimo bro
scare-crow's Avatar
if you have any more info on the swap let me know
Old December 9th, 2010, 05:09 PM   #11
Yetti
Yetti's Avatar
try a few of the links from this page and you may find a source for more info
http://www.sciencehilldrifters.com/links.htm
Yetti
Page generated in 0.83880 seconds with 56 queries
