05 Buick coolant temp - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2010, 08:48 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default 05 Buick coolant temp
'05 Buick LeSabre, 3800 series II V6.
How can I check the coolant temperature sensor for a fault, using a mulitmeter?
Old December 3rd, 2010, 06:46 PM   #2
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Old December 3rd, 2010, 06:56 PM   #3
Ebs
OBD Scanner?
Old December 4th, 2010, 01:08 AM   #4
Disturban
Disturban's Avatar
If you suspect it is faulty just replace it, they are like $12
Old December 4th, 2010, 09:03 PM   #5
HVYRTFT
Reed my teef
HVYRTFT's Avatar
had it scanned, the autostoners said it 'might be' the coolant temp sensor.
I didn't know they were that cheap. I'll try it.
Old December 5th, 2010, 01:47 PM   #6
cronus
cronus's Avatar
With the engine cold, measure the resistance of the sensor. Then look it up in the temp / resistance table to see if it is correct. It's model specific so you'll need a repair manual.
cronus is offline   Reply With Quote
Old December 5th, 2010, 02:00 PM   #7
hondadirtracer
Skymaster
hondadirtracer's Avatar
Go here for repair manual.
Free usage of Chiltons online manuals - Great Lakes 4x4. The largest offroad forum in the Midwest
hondadirtracer is offline   Reply With Quote
Old December 11th, 2010, 03:26 PM   #8
RADRICK
RADRICK's Avatar
what was the code? If it was coolant temp below threshold- p0128, it will probally need a t-stat. The t-stats are pretty common.
Page generated in 0.30216 seconds with 48 queries
