Ram front end question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 2nd, 2010, 08:01 AM   #1
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Default Ram front end question
I'm trying to figure out whats hammering under my plow truck today
I have a 1997 3/4 ton V8 Ram.
I have eliminated the CAD (put the PosiLock in place)
Today after plowing my entire rout something started just hammering under the truck feels like drive shaft.
My question is with the front axle unlocked (posilock system not engaged) and the transfer case in 2wd does my drive shaft still spin?
Old December 2nd, 2010, 08:06 AM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Easy to tell, just crawl under there while its unlocked and in 2wd and see if you can spin the driveshaft.
Old December 2nd, 2010, 08:09 AM   #3
xj nut
maxin out the 30
xj nut's Avatar
hammering?
xj nut is offline   Reply With Quote
Old December 2nd, 2010, 08:10 AM   #4
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
In can because you still have the drivers side axle connected which will spin the spiders and with enough momentum or friction the carrier will spin. This will cause the drive shaft to spin. There will be no load on the shaft though. You should be able to spin the shaft by hand with everything disengaged.
GNJEEPN is offline   Reply With Quote
Old December 2nd, 2010, 08:12 AM   #5
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Thats what I was thinking.
I think the CV end of my shaft is gone very small amount of slop in it replaced 2 years ago.. Axle joints new last year. Must be the cv end.
Poop
Old December 2nd, 2010, 11:40 AM   #6
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Ooooooor
it could be all the lug nuts are loose hahahahh
FML
Old December 2nd, 2010, 12:24 PM   #7
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Originally Posted by Mr. Beefy View Post
Ooooooor
FML
Page generated in 0.21090 seconds with 44 queries
