Jareds mini tj build - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 25th, 2010, 01:30 AM   #21
jared
Can't Worry About It
jared's Avatar
Originally Posted by stuckinthemud View Post
good plan dont want the body to dig into the new rubbers i got a lifted ranger now and suzuki samurai and zacks 90 toyota haha. when you comin back to town
I'm thinking spring. I wanna road trip it tho. I have 3 weeks vacation saved so idk haha. I need to win the lottery.
jared is offline   Reply With Quote
Old December 25th, 2010, 10:59 AM   #22
Frank01TJ
Frank01TJ's Avatar
Didn't some magazine build a no lift TJ running 40's?
Frank01TJ is offline   Reply With Quote
Old December 25th, 2010, 12:02 PM   #23
jared
jared's Avatar
Petersons 4wd had chris durhams jeep on 40s for the ultimate adventure. he makes lexan (or similar) super high clearance hoods with little fenders molded in. His rig is hard to find any info on tho.
Old December 25th, 2010, 12:50 PM   #24
jared
jared's Avatar
Here's a morning pic in the driveway. That's rear ride height with 35s and stock in the front.
Still need to cut the rear and install the front fenders after paint. And the tummy tuck arrives on the 28th so I'll have a busy next weekend.
I'm thinking getting the front fenders painted green to match but not sure on the price. So maybe rustoleum semi gloss black on the cheap.
But the metalcloak powder coating is amazing. They sent out the battery brackets powdercoated textured black and I can say I wish I would have had the extra money to spend on the powder coated fenders. But when I save up for the flares they will be powdercoated.
Old December 25th, 2010, 03:38 PM   #25
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
There was a no-lift TJ on 35" tires, as well.
So is there any lift in the back yet, or is that on stock springs?
Craig
Old December 25th, 2010, 05:57 PM   #26
jared
jared's Avatar
That's stock springs Craig. I have a set of rubi springs somewhere. Need to find them still after the move. But I'm only going to adjust it if the tires need more clearance, most of which can probably be fixed with trimming.
Old December 26th, 2010, 11:36 AM   #27
jared
jared's Avatar
It's 74" wide outer sidewall to outer sidewall.
About 7.5" sticking out past the tub with no flares
Stock flare adds 4" coverage but still exposes 3-4" of tire
Old December 26th, 2010, 01:17 PM   #28
jared
jared's Avatar
Here's the clearance between a stock d35 (poison spider cover) it's 6" to the indentation, 5" everywhere else. Allowing up to 5" of wb stretch.
The skid also sits lower in the front (axle side) and ramps up to the rear of the jeep giving a nice departure angle.
Old December 26th, 2010, 02:25 PM   #29
jared
jared's Avatar
Went to the gas station. My bro pulled me. I guess it was the actual first usage of my winch lol.
I need a new rubber filler neck and clamps, this one leaks somewhat. But it's noticeably heavier in the rear now too. That tank is light since it's aluminum, but the skid is so heavy.
On a good note, I found my new front swaybar links so I can hook it back up since it's been off for 2 years. The extra weight from the winch, winch plate, fuel tank, fenders, and tummy tuck will make the body roll a little too much for street use without it now.
Old December 26th, 2010, 02:37 PM   #30
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Looks good. Love the look of Low TJ's.
Old December 26th, 2010, 04:50 PM   #31
sanddude
sanddude's Avatar
cool build.
sanddude is offline   Reply With Quote
Old December 26th, 2010, 05:24 PM   #32
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Originally Posted by Jeepaholic View Post
93-early 96 I believe Zj front 30 uses a long pinion crush sleeve design but you can use Cj 30 gears (which are available in 5:38s) with a different pinion bearing. The Zj axle will bolt in.
You have the 2.4? If so I see a turbo in your future
o rly may be time to ditch the hp 30 for one of these
Old December 27th, 2010, 02:36 PM   #33
jared
jared's Avatar
Dropped my fenders off at glendale powder coating this morning. For just tge steel fenders in semi gloss black only 65 bucks. Hoping to have them back before the weekend.
Tummy tuck delivery is scheduled for tomorrow, hope im home to recieve it.
Old December 28th, 2010, 12:35 PM   #34
jared
jared's Avatar
Bailed out of work to install my rear metalcloak flare mounts. Broke a 3/8 drill bit, home depot charges $10 for a new dewalt one like I had or I can pay 20 and get a 14 piece set hmmmm better deal
Old December 28th, 2010, 05:53 PM   #35
jared
jared's Avatar
Tummy tuck arrived. Shiny!!
Been busy cutting up my baby this morning.
Finished cut
Old December 28th, 2010, 11:26 PM   #36
jared
jared's Avatar
I took some measurements of my jeep stock, just so I can keep track of everymod I do to measure if I gain or lose clearance.
The lowest points of my jeep right now are the diffs and the shovel. All measure up at 8".
The gas tank originally had 9", now it's at 10" at the lowest point and 11" at the rear. But it's partially suspension gain since the jeep is now sitting higher also in the rear due to no spare tire mounted.
With the 35s on it measured 12" to the bottom of the diffs.
So we have 3 1/2" gained in the front
Should be between 6-7" at the belly with tummy tuck
And around 5" at the gas tank.
My jeep does have a more noticeable rake on it now, a front spacer may be on order, or find my rubi front springs and test them out.
Old December 28th, 2010, 11:38 PM   #37
jared
jared's Avatar
Here's some old wheeling pics from my friends back yard. My buddy just sent them too me
Old December 29th, 2010, 01:58 PM   #38
green50gt
Got rocks?
green50gt's Avatar
Huh. I am going to be watching this. Nice.
I heart Jeeps
green50gt is offline   Reply With Quote
Old December 30th, 2010, 12:41 PM   #39
jared
jared's Avatar
So my fenders are done at the powder coaters. Hope to pick them up before 4:30 or I can't get them till after new years.
Old December 30th, 2010, 01:07 PM   #40
green50gt
Got rocks?
green50gt's Avatar
Yes go..hurry! I have somewhere around a 1/2-3/4 erection in anticipation of how this is going to turn out. Previously I have honestly hated how those metal cloak things look, but b/c of this build I am starting to like them.
I heart Jeeps
Page generated in 1.19988 seconds with 83 queries
