Heim joints - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2010, 07:22 PM   #1
noodles
give 'er sh*t ay?
noodles's Avatar
Default Heim joints
Which Heim joint have you gone with and why? I am looking at the Creeper joint from Foothill offroad.com I was just looking at some feed back on the other joints. The Johnny joint, teraflex joint, Rubecon express joint. Just courious to what you have heard about all of them
-R-
Old November 28th, 2010, 08:26 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
here ya go ryan
http://www.ballisticfabrication.com/...nt_p_1626.html
Old November 28th, 2010, 08:46 PM   #3
Tab
Tab's Avatar
ballistics tend to wear out very quickly. They can be adjusted but you better like doing it before every trip. No fun. I personally have johnny joints and couldn't be happier. Zero slop after 2 years of use and if ever needed they are very easy to rebuild. I went with the 1" shank and should have gotten the 1.25 shank because if my jam nuts gets loosened on a rock the 1" shank tends to bend a bit. Although I got a good way of fixing them in a press now.
Old November 28th, 2010, 09:40 PM   #4
rangerluc
rangerluc's Avatar
Heims Joints - Great Lakes 4x4. The largest offroad forum in the Midwest
rangerluc is offline   Reply With Quote
Old November 29th, 2010, 09:00 AM   #5
liv2mx
i like jungle gym's.
liv2mx's Avatar
anything that you can adjust stay away from.they fall apart fast.ruff stuff make some sweet inch and a quarter heims.i have had johnny joints for 4 years.have one bad now, so i am putting all big ruff stuff heims in now.
Old November 29th, 2010, 09:10 AM   #6
Bones
Bones's Avatar
buy rough stuff heims, and replace them every ~3 years. Still a ton cheaper than JJs, summit joints, etc.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 29th, 2010, 09:19 AM   #7
Eric99tj
Just bump it....
Eric99tj's Avatar
JJ's with 1.25" shank are under $40.... The Ruff Stuff 1.25" heim alone is $48... That is not even including misalignment spacers for the heims... JJ's are a solid way to go. Been running JJ's with 1.25" shanks for over 3 years with zero issues.
Eric99tj is offline   Reply With Quote
Old November 29th, 2010, 10:40 AM   #8
Bones
Bones's Avatar
99.9% of the people here don't need a 1.25" heim joint. A 3/4 heim joint will be plenty strong and survive for years, and they are only $13 a piece. A 1.25" heim would last longer than the rig it is installed on.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 29th, 2010, 11:49 AM   #9
95geo
newbie
95geo's Avatar
A 3/4"x7/8" is the bare minimum for a lower link and then you're into bending shanks. That puts you up to a 1x1 with a misalignment/ reducing spacer and at that point, you might as well do a 1x1.25 so you never have to worry about it.
If you get ballistic joints you have to get the solid races otherwise they don't last.
I like how low maintenance the currie Johnny joints are. You can also get them with 5/8" thru bolts if you order them correctly. And currie has some of the best prices on jam nuts I've found.
Old November 29th, 2010, 01:21 PM   #10
Bones
Bones's Avatar
Then you're adjusting your heim joint out way too far. You shouldn't bend a 3/4 x 7/8 heim. I never even bent a 3/4 3/4 on my old rig. Look at the abuse Mike's old rig held up to as well.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 29th, 2010, 01:22 PM   #11
fabguy01
hammer down grabbin gears
fabguy01's Avatar
We've run the FK or QA1 chromo's for years the only time we had issues is if we were in a wreck.i should note this is in a short course off road race enviroment, Brutal
fabguy01 is offline   Reply With Quote
Old November 29th, 2010, 02:06 PM   #12
95geo
newbie
95geo's Avatar
People bend 7/8" shanks, it happens. 3 threads sticking out is enough to do it. The other stress riser is between the threads and the bore for the spherical bearing. I've seen them stretch and tear in that area.
But none of those failures happen during typical use. Usually landing on a link near the ends is what will cause a failure.
That's why I think it's cheap insurance to get 1.25" lower shanks and at least 3/4" upper shanks with 5/8" or larger bolts.
Old November 29th, 2010, 02:24 PM   #13
Chop
Mischievous Badger
Chop's Avatar
I love my FK 1.25" lowers and i don't have to worry about them at all. JJ are the best i have see so far as a rebuild able joint like that.. i have heard and see the ballistics wear out quick and the creeper joints fall apart.
Old November 29th, 2010, 07:16 PM   #14
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
silly question - how does this translate to choosing a sufficient joint for OTR use?
@clarkstoncracker
Old November 29th, 2010, 08:28 PM   #15
95geo
newbie
95geo's Avatar
For your application- I'd do currie Johnny joints. 1" shank lowers with 9/16" bolts. For the upper, 3/4x7/8 heims on the frame and a 1.25x1.0 on the axle with the bolt vertical.
If you want something specifically different then you can make some substitutions without and downsides.
Old November 30th, 2010, 09:04 AM   #16
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
I sure like reading this. My junk will be using 3/4 x 3/4 heims. I have worried about how long they will last. I think I will carry spares and try not to think about it.
RIP FULLSIZE4LIFE
Old November 30th, 2010, 09:11 AM   #17
liv2mx
liv2mx's Avatar
i can get ruff stuff 1 1/4 heims with bung,misalignment and jam nut for 52 bucks each.they actually have deals from ruff stuff 100 a link.extreme off road always has good deals on these heims also.
Old November 30th, 2010, 07:46 PM   #18
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by liv2mx View Post
i can get ruff stuff .... bung,misalignment and jam nut....extreme ...
Sorry, is it wrong that this makes my shorts get tight?
@clarkstoncracker
Old December 1st, 2010, 08:53 AM   #19
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
casey says your prices suck and he can get them much cheaper
Old December 1st, 2010, 09:23 AM   #20
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I'd recommend 3/4x5/8 heims over 3/4x3/4 due to the increase in strength. Or at least compare them before buying. Last I remember most 3/4 x 3/4 heims were rated at about 25K, vs 40K on the 3/4x5/8. (3/4" shank with 5/8" bolt)
Page generated in 0.47762 seconds with 84 queries
