First Cold Start of year and now oil leak!? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 27th, 2010, 05:37 PM   #1
94transam25th
94transam25th's Avatar
Default First Cold Start of year and now oil leak!?
Ok so this is the first time its been cold by me and i wanted to see how the truck started when cold so i left it unplugged over night. I went to start it about 6am and it started right up but i noticed it started leaking quite a bit of oil
i havent had a chance to look at it in the light yet so i dont know where its coming from but any ideas on what i should check?
it never leaked a drop of oil before this
the trucks an 02 7.3
thanks,
Brandon
94transam25th is offline   Reply With Quote
Old November 27th, 2010, 05:40 PM   #2
jeepbrattt
New car smell.....Mmmmmmm
Mine was a tiny little o ring on the backside of the block. !0 cent part. Also have the 7.3
jeepbrattt is offline   Reply With Quote
Old November 27th, 2010, 05:45 PM   #3
94transam25th
hmm hopefully thats what it is. i didnt notice it while running just when i got home i notice about a 6 inch diameter oil spot
do u have any idea what it was called?
Old November 27th, 2010, 05:48 PM   #4
jeepbrattt
My deisel guy is in highland, if you want his # i will pm it to you. Don't remember what he called it, but i had a hell of a lot more oil on the ground then that
Old November 27th, 2010, 06:02 PM   #5
dzltech
Look in the valley between the heads, if its full of oil it's probably one of the hpop oil lines going to the heads. Cheap and easy fix but they can pour out a lot of oil quickly, these engines are notorious for it. Also make sure the fittings for the lines are tight in the hpop and heads as I have seen them come loose and leak. They sometimes start leaking slowly but will get worse over time. Oil can only run out a hole in the back of the block and usually looks like a rear main leaking but the 7.3's rarely leak at the rear main. Also look at the turbo base seals if its not the hpop lines leaking, they like to leak too.
dzltech is offline   Reply With Quote
Old November 27th, 2010, 06:04 PM   #6
Bishop
Bishop's Avatar
look first. Ask questions later.
Old November 27th, 2010, 06:21 PM   #7
94jimmyjr
94jimmyjr's Avatar
oil pans rot out on them also
94jimmyjr is offline   Reply With Quote
Old November 27th, 2010, 08:36 PM   #8
94transam25th
hmm so i just went out and messed with it for awhile an still cant figure it out. I started the truck and ran it for prob 20 mins and didnt see a single drop leak. So i shut it down and then let it sit for about a half hour and no drips again
now i just let it warm up for about 10 minutes and then drove it a few blocks over to the park and let it run while i let my dog run, i got home parked it in the driveway again and now its leaking
im thinking now it could have something to do with the tubo because right underneath the "T" on the outlet of the turbo to the intercooler seems a little wet
if it were an HPOP problem wouldnt it be leaking toward the front of the motor?
thanks for the help guys
Old December 2nd, 2010, 09:16 AM   #9
Quiefinator
go'til itsounds expensive
Check the grill, if theres a blue oval on it,
its probably gunna leak.
Old December 4th, 2010, 07:54 AM   #10
88fordman
88fordman's Avatar
Agree on the hpop line fitting and the rusted oil pans. There is an updated connector kit for at the pump. Watch out, like dzltech said if that leak wants to it can dump out oil like crazy.
88fordman is offline   Reply With Quote
Old December 5th, 2010, 05:44 PM   #11
frdboy
frdboy's Avatar
Your exhaust back pressure valve actuator in the turbo pedestal could be leaking, or the pedestal o-rings themselves.
I have also seen the oil cooler o-rings leak only when cold, lower left side of the block, towards the front. Long cylinder shaped item.
Page generated in 0.29023 seconds with 56 queries
