. - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2011, 05:22 PM   #101
95geo
newbie
95geo's Avatar
Yup. In fact, on a lot of 6.0/4L80e combos had that spacer as an OEM piece, because they didn't make a longer snout 4L80e.
Make sure you get the longer crankshaft bolts as well to go with it.
Torque converter bolts.... The flexplate has to stay where it is or the starter won't line up correctly. Most of the adapters I have seen don't use any of the crankshaft bolts to fasten it but if the one she gets does then those are needed too.
If you do use longer crankshaft bolts make sure they aren't too long or you'll lock up the engine by bottoming out on the bearing cap.
Old January 23rd, 2011, 06:48 PM   #102
Keep in mind mine is a 6.0 mated to a TH350. Flex plate stayed the same. I had to slot the holes in my flex plate because the 3 bolt pattern is slightly different in the torque converter. The only difference I had was I needed the pilot spacer/adapter.
Old January 23rd, 2011, 07:29 PM   #103
I was referring to the GM performance parts spacer. This one goes after the flexplate, between the plate and the converter. This style requires bolts which are 0.400" longer.
http://www.summitracing.com/parts/NAL-12563532/
the bolts:
http://www.summitracing.com/parts/NAL-12563533/
goes like in this pic: (from pirate)
Old January 23rd, 2011, 07:33 PM   #104
here are the facts about fitting an old style trans to the gen3 engines
1. the gm gen1,2 trans will bolt to the gen3 engines but you only use 5 bolts, the gen 3 engines do not use the middle bellhousing bolt on the pass side( no big deal)
2. you do not need a special flexplate, the curved 4.8,5.3,LS1- just need the t/c bolt holes ovaled out a bit and the 5.3 flex plates have a set of holes that match the small gm t/c bolt pattern perfect
- the 6.0 flat flex plate has the same t/c holes as the large gm pattern(th400 and most aftermarket th350 converters that have a dual t/c bolt pattern on them)
3. you need to use a crankshaft spacer when using a gen1,2 trans and converter there are 2 types:
- hughes gen3 crankshaft spacer part # hup-3795 $44 from summit/jegs, this spacer must be used with the curved 4.8,5.3,LS1 flexplates
- gm stock 6.0 crankshaft spacer 12563532 and longer bolts 12563533, this spacer can be used with either the flat or curved flexplate ( if using the curved style flexplate the flexplate goes on the crank first then the spacer goes on then the bolts, if using the flat 6.0 flexplate the spacer goes on the crankshaft first then the flexplate then the bolts)
So, in the pic above, thats correct for an LS1 or 5.3. And then it appears it'd go the other way for a 6.0, which was the factory configuration. Really depends on what flexplate setup she has.
Old January 23rd, 2011, 07:40 PM   #105
I think this is the style you were thinking of?
http://www.summitracing.com/parts/HU...5&autoview=sku
Really really check the flywheel to see which you have.
Old January 23rd, 2011, 07:47 PM   #106
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
why if it came on that motor just run it
Old January 23rd, 2011, 09:11 PM   #107
jeepm715
DEAK Racing
jeepm715's Avatar
I just did one of these, D&E Transmission on 10 mile near dequindre has a kit for the 4L80 that has the flexplate, Spacer, and bolts to make it all work for about $80. The correct bolts from GM are about $5 each, plus the spacer, the flexplate is almost free in the kit.
Edit: I take that back, Summit claims $10.99 each for the bolts, and they are specific for the flex plate, as Geo said, don't get them too long!
jeepm715 is offline   Reply With Quote
Old January 24th, 2011, 01:28 AM   #108
Shotgun
I only wheel with boats.
Shotgun's Avatar
Ordered this and bolts. Found them in a 6 pack for about half the price.
Becky you overpaid......
http://www.gmpartsdirect.com
GM PART # 12563532
CATEGORY: Engine Flywheel
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $53.39
OUR PRICE: $31.04
GM PART # 12563533
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $6.93
OUR PRICE: $4.02
You can order a extra bolt from summit for the one that WILL get lost.
Old January 24th, 2011, 05:23 AM   #109
Shotgun
Shotgun's Avatar
At work, thats why I had time to look.
Old January 24th, 2011, 05:52 AM   #110
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
i wants a job viewing the interwebz too.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old January 24th, 2011, 06:50 AM   #111
bbaXJ
Yooper In Training
bbaXJ's Avatar
I'm almost positive the 6 hole flexplate I gave you with the engine already had the spacer with it and just needed the longer bolts
Old January 24th, 2011, 09:38 AM   #112
liv2mx
i like jungle gym's.
liv2mx's Avatar
that's what i thought also.
Old January 24th, 2011, 09:43 AM   #113
liv2mx
liv2mx's Avatar
use a mechanical fan not an electric for the radiator. she will always forget to turn it on or off if electric.
Old January 24th, 2011, 09:45 AM   #114
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
They can set up the ecm to do that.
RIP FULLSIZE4LIFE
Old January 24th, 2011, 10:00 AM   #115
bbaXJ
Yooper In Training
bbaXJ's Avatar
He went thru all the parts I gave him, but I will have him double check.
It's on the motor already.....
Old January 24th, 2011, 10:04 AM   #116
With a high horsepower/ high heat engine, I always found the need for my fan to run longer than just shutting off with the engine. So, I went to a thermostat controlled one. That was fine until the friggin thermostat switch failed.
Stay mechanical. If it's good enough for GM, it's good enough for Becky.
Old January 24th, 2011, 10:12 AM   #117
liv2mx
liv2mx's Avatar
i am sure i saw it. she told me yesterday about that and it did not make sense to me, because i thought all that was already there.
Old January 24th, 2011, 10:13 AM   #118
liv2mx
liv2mx's Avatar
i remember you saying that.
Old January 24th, 2011, 12:47 PM   #119
Good job sonny. You keep remembering things I say and you might just turn out alright.
Old January 24th, 2011, 03:43 PM   #120
bbaXJ
Yooper In Training
bbaXJ's Avatar
I'm surprised they'd take the spacer and not the flexplate. I remember when I took the old 3 bolt dished flexplate off(engine was originally mated to a 4L65E) to replace it with the 6 bolt right before you came and got it, the spacer was pressed pretty tightly into the flexplate.
Page generated in 0.51536 seconds with 84 queries
