. - Page 59 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 15th, 2012, 03:57 PM   #1161
mboies
BS MUDDERZ
mboies's Avatar
Cant you order a steel outer ring?
mboies is offline   Reply With Quote
Old June 17th, 2012, 09:01 AM   #1162
slim41778
tj at baker engineering in nunica michigan can custom tune any ls motor so call him hes a little genius very good
slim41778 is offline   Reply With Quote
Old June 17th, 2012, 09:19 AM   #1163
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Ok, no more cheap ass aluminum........
buy better wheels, and they wont be "cheap aluminum" with wheels you really pay for what you get. look into BTR race wheels. I bet you find it hard to break them.
Old June 17th, 2012, 09:30 AM   #1164
1TFROT
1TFROT's Avatar
They are not aluminum. They are a secret space age material.............
unobtainium
1TFROT is offline   Reply With Quote
Old June 21st, 2012, 10:49 PM   #1165
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Being shipped out tomorrow morning.
I bet you are drooling on your laptop
Old June 22nd, 2012, 07:50 AM   #1166
1 ton tj on 40's
1 ton tj on 40's's Avatar
thats a poor site
Old June 22nd, 2012, 08:10 AM   #1167
Grassman
2jz specialist
Grassman's Avatar
You got a soft tire...
Old June 22nd, 2012, 08:15 AM   #1168
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Smokey burnout time
Old June 26th, 2012, 09:23 PM   #1169
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Gonna look sweet on your rig. Gonna have it ready for this weekend?
Old June 26th, 2012, 10:29 PM   #1170
tw1st3d5
tw1st3d5's Avatar
Nope, and the towrig is grounded from towing right now. Dave comes and gets it Thurs morning...steering issues. I may come watch tho, have the weekend off, will have to see what the $$ is
What kind of steering issues on the Excursion? I've been having some issues lately and I can't figure out what is going on.
Old June 27th, 2012, 07:11 AM   #1171
tw1st3d5
tw1st3d5's Avatar
Steering damper.......have already replaced a few parts. It's just REALLLL sloppy. Replaced a few other parts over the winter...that helped but didn't fix the issue totally, hopefully this will. Rotated the tires as well and the rear brakes are shot as long as the rotors paper thin. He will be fixing my trailer brake hook up too..thinking theres something off in the pigtail....it'd be nice if the brakes on the trailer could help out a bit.
I adjusted the nut on top of the steering box and that took a lot of the slop away. My issue is after a hard turn the steering wants to stay that direction and I have to hold the wheel. It will then want to bounce back and forth real bad. I've replaced almost the whole front end with no help in it. New ball joints and tie rod ends included, brand new tires as well.
Old June 27th, 2012, 07:21 AM   #1172
hamsmotorsports
hamsmotorsports's Avatar
Are the front axle u joints good? Sounds like that could be your problem.
hamsmotorsports is offline   Reply With Quote
Old June 27th, 2012, 01:57 PM   #1173
tw1st3d5
tw1st3d5's Avatar
That was going to be my next think to pull apart. I need to replace my hubs with manual ones to get rid of the crappy stock ones so I'll check them then.
Old June 27th, 2012, 02:15 PM   #1174
exactly my thoughts, I have a 03 SD with a powerstroke in the shop right now that has this same issue. Lifted in the air I can't turn the wheel left to right the joints are so stiff. I had the same problem with my 97 f350. That got real interesting when I put it in 4wd and tried to turn .
Old June 27th, 2012, 02:21 PM   #1175
RADRICK
RADRICK's Avatar
If the steering box is adjusted too tight, the steering wheel will not "return to center" after turning. The name for this is "memory steer", generally caused by binding axle joints/ball joints or steering box adjusted too tight! I would guess the bouncing back and fourth is the axle joint bind when turned.
Old June 27th, 2012, 03:40 PM   #1176
tw1st3d5
tw1st3d5's Avatar
I thought this was a jeep build thread???
I was just thinking that. Sorry to hijack it.
Old June 27th, 2012, 03:46 PM   #1177
You brought up tow rig and steering issues
Old June 27th, 2012, 05:14 PM   #1178
Grassman
2jz specialist
Grassman's Avatar
And there isn't much jeep left anyway
Old June 27th, 2012, 08:43 PM   #1179
See you saturday
Old June 27th, 2012, 08:58 PM   #1180
tw1st3d5
tw1st3d5's Avatar
Maybe...depends if the truck is back together or not......
There you go talking about that truck again in the JEEP BUILD THREAD!
Page generated in 0.45689 seconds with 84 queries
