. - Page 57 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2012, 02:08 PM   #1121
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
The intake kit is the Spectre 9900. Joescamaro hooked me up with the info on that. Yes, you could flip the intake around and run it that way, I actually asked about it but there was room so why bother with that. The kit comes with a shroud if you want to use it. My cowl is pretty much wide open and the motor never got above 180 all weekend. I had to order the piece that goes from the air cleaner to the MAS seperate or you can go hunt a junkyard. Way more responsive.....highly recommend this kit. The piece of tube that comes with it is long enough to cut and use in the 2 seperate places.
You can find them anywhere from $149-$200.
Shouldn't these motors run 210 for best power numbers?
Old May 7th, 2012, 02:30 PM   #1122
Grassman
2jz specialist
Grassman's Avatar
Not in my experience, having your intake in the cab sucks asshole
bicycles have intakes?
Old May 7th, 2012, 02:49 PM   #1123
kickstand
circling the drain
kickstand's Avatar
Yes, I never owned a vehicle, so I put a K&N on my tricycle
Old May 7th, 2012, 05:19 PM   #1124
John D
John D's Avatar
Thanks, I gotta do something. I hit 170 IAT on the street and peg the gauge on the dunes.
The 5.3L comes with a 186* thermostat, I imagine the 6.0 is the same or very close. A lot of people drop it to 180*.
Old May 8th, 2012, 01:40 PM   #1125
BigBlockBlazer
Axle breakin' 101
The 5.3L comes with a 186* thermostat, I imagine the 6.0 is the same or very close. A lot of people drop it to 180*.[/QUOTE]
Huh, that's interesting. Both my work trucks have 5.3's and they both run right at 210 always.
Old May 8th, 2012, 02:03 PM   #1126
John D
John D's Avatar
It's just where it opens ( 186*) not where it runs. 195-210 would be normal operating temp.
http://shop.advanceautoparts.com/web...RPCOOLAMS_____
I got mine from NAPA, its the same 186* stat but their website is impossible to navigate.
Sorry for the confusion.
Old May 8th, 2012, 07:39 PM   #1127
electricleader
electricleader's Avatar
I dont know who did your computer but you might want to check with them because alot of tuners will set the computer for a 160 stat just it helps with detonation on the 6.0
electricleader is offline   Reply With Quote
Old May 8th, 2012, 08:25 PM   #1128
knixon804
THE GENERAL
knixon804's Avatar
hey becky do you have the part number for that MAF to air filter adapter? i need to move my MAF i think
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JK 3" BDS LIFT, 33" DURATRACS, STEELIES, WARN
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old May 9th, 2012, 08:21 PM   #1129
6.0 thermostat is 100*C or 212*F.
Old May 9th, 2012, 08:56 PM   #1130
knixon804
THE GENERAL
knixon804's Avatar
That's what I thought
Old May 9th, 2012, 10:05 PM   #1131
John D
John D's Avatar
Just curious, where did you find that? I found 160, 180, 186 and 195. I couldn't find a 212.
Old May 10th, 2012, 06:14 AM   #1132
I didn't buy one, I used the one that came with my engine. Have I personally seen a 100*C stat? No, it's just what I have read and that's where my engine runs. Using my scanner running real time and leaving it hooked up while wheeling, my engine stays right around 208 - 210*F.
Old May 10th, 2012, 08:12 AM   #1133
knixon804
THE GENERAL
knixon804's Avatar
I would say yes. Here's my take on it. I have a scan gauge 2 in my jeep at all times. It constantly reads and displays 4 parameters of my motor. I had the same 180 degree intake setup as u and was reading super high air intake temps. Which was making my motor run hotter. I drilled some holes in my hood and stuck my air filter out that way and both cooled my motor and air intake temps.
Old May 10th, 2012, 08:21 AM   #1134
Did you move the Maf? The intake air temp sensor is integrated into the Maf. You will heat soak that sensor if it's right by the radiator. Your intake air may be just fine, the temp it reads is a different story. My chevelle has the same issue right meow.
Old May 10th, 2012, 01:32 PM   #1135
stereoguy
2jz NO SH*T!
stereoguy's Avatar
I moved my MAS to right next to the filter by the cowl. My cowl being basically open is like Kyle's added holes. Sure did make a difference.
Is it me or does this statement sound kinda dirty? Sorry jeepbratt, that is all the tech Ive got.
stereoguy is offline   Reply With Quote
Old May 10th, 2012, 08:54 PM   #1136
knixon804
THE GENERAL
knixon804's Avatar
lol u guys have dirty minds...
Old June 11th, 2012, 07:34 PM   #1137
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Sweet!
All 5?
Old June 11th, 2012, 07:39 PM   #1138
Tacker
Tacker's Avatar
Nice .
Old June 11th, 2012, 07:47 PM   #1139
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Baller
You have some nice parts, good work.
Old June 11th, 2012, 08:02 PM   #1140
tw1st3d5
tw1st3d5's Avatar
You'll love the rockers! They seem to work and take my rig wherever I point it for the most part.
Page generated in 1.15056 seconds with 84 queries
