. - Page 37 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2011, 04:43 PM   #721
MiNi Beast
MiNi Beast's Avatar
Do I need to come up there??!!
I think that's his idea, you go up there and drop off the jeep.
Old April 28th, 2011, 06:10 PM   #722
jeepbrattt
New car smell.....Mmmmmmm
Tom talked to Troy at Howell today. He says he has programs to make the 93 4l80 work with the newer computer. Not an issue. Tom may have to add or change a couple wires for the torque converter and that is that. I'll have it tuned while it's there to see why it's pulling that 171 code and make sure all is working and reading correctly.
Tonite the stereo will be set up to run just on an ipod. Thanks Zac for coming out to do that. Can't wait to see how well that works.
jeepbrattt is offline   Reply With Quote
Old April 28th, 2011, 06:45 PM   #723
unrelated note, but since there's a few pics now, is it staying cool without the rad shroud, or have you not really driven it enough? I'm guessing not with the trans issues.
I'm debating if I want to use the stock plastic fan and make a shroud or use my nicer CJ dual electric fan..
Old April 28th, 2011, 07:42 PM   #724
jeepbrattt
I haven't drivin it enough to know, however I plan on switching to an electric fan as soon as I can.
The stereo is out and the ipod is running the system. He is hooking up the subs right now. I'm impressed....this guy knows his stuff! The ipod will be kept in the glove compartment with a long enough wire to comfortably be ran by passenger or driver. Will be ran by key so i don't forget to turn a toggle switch off and oops.....dead battery. volume control switch has a small amp on it for added power from ipod. Will post pics when job is done. Took a few of fab work and how exhaust was ran while i was out there.
Old April 28th, 2011, 08:21 PM   #725
Several comments.
1) Now that it has a useless stereo in it, I don't want it.
2) I strongly advise against an electric fan. (ask Benny how that worked out at Bundy Hill today)
3) Put a fan shroud on the stock OEM fan and never worry about cooling again.
4) Glad you are making progress.
Old April 28th, 2011, 08:25 PM   #726
jeepbrattt
Several comments.
1) Now that it has a useless stereo in it, I don't want it.You weren't getting it anyway!!! But it's not a stereo...it's an ipod!
2) I strongly advise against an electric fan. (ask Benny how that worked out at Bundy Hill today) Alrighty
3) Put a fan shroud on the stock OEM fan and never worry about cooling again. I'll get on that
Thanks!! Me too!!
Old April 28th, 2011, 09:07 PM   #727
jeepbrattt
Here's a few pictures of the wiring the ipod in jeep. I'll be putting a little storage cubby where the stereo used to go. It sure sounds good!
Name:	jeep stereo 020.jpg
ID:	78197   Click image for larger version
Name:	jeep stereo 021.jpg
ID:	78198   Click image for larger version
Name:	jeep stereo 022.jpg
ID:	78199   Click image for larger version
Name:	jeep stereo 027.jpg
ID:	78200   Click image for larger version
Name:	jeep stereo 036.jpg
Name:	jeep stereo 037.jpg
ID:	78203   Click image for larger version
Name:	jeep stereo 038.jpg
Old April 28th, 2011, 09:11 PM   #728
jeepbrattt
You can kind of make out the 2 amps. 1 running the subs the other the tower speakers. Zac made this look easy.......too many wires for me!
Name:	jeep stereo 023.jpg
ID:	78205   Click image for larger version
Name:	jeep stereo 024.jpg
ID:	78206   Click image for larger version
Name:	jeep stereo 025.jpg
ID:	78207   Click image for larger version
Name:	jeep stereo 026.jpg
Old April 28th, 2011, 09:19 PM   #729
jeepbrattt
Here's a couple of the exhaust and Kevins handy work on the radiator, computer mount and skid.
Name:	jeep stereo 028.jpg
ID:	78209   Click image for larger version
Name:	jeep stereo 030.jpg
ID:	78210   Click image for larger version
Name:	jeep stereo 029.jpg
ID:	78211   Click image for larger version
Name:	jeep stereo 031.jpg
ID:	78212   Click image for larger version
Name:	jeep stereo 035.jpg
Name:	jeep stereo 032.jpg
Old April 28th, 2011, 09:50 PM   #730
knixon804
THE GENERAL
knixon804's Avatar
finally some pics!!!
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JK 3" BDS LIFT, 33" DURATRACS, STEELIES, WARN
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old April 28th, 2011, 10:33 PM   #731
MiNi Beast
MiNi Beast's Avatar
music will come in handy when just sitting there cause you can't drive it
Old April 29th, 2011, 06:16 AM   #732
buzz700r
my name is mud
buzz700r's Avatar
To install the Ipod to drive speakers is pretty straight foreward. I used an Ipod to rca cable with charging capabilities. That is inputed to a 5 volt preamp line driver with gain adjustment. The line driversends the amplified input signal to her existing amps & speakers. Total damage with parts and labor is about $200. and there is no radio to fry out. This setup can also be configured to work with a universal 1/8th inch plug to work with any input source (ie phone, walkman, etc).
buzz700r is offline   Reply With Quote
Old April 29th, 2011, 07:21 AM   #733
jeepbrattt
My junks on the trail a hell of a lot more then yours my dear!
Thanks Zac!!
Old April 29th, 2011, 07:23 AM   #734
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
True story.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old April 29th, 2011, 08:59 AM   #735
tsk tsk tsk....... all that wasted money on noise.
Glad you got a decent skid on the oil pan.
Old April 29th, 2011, 01:11 PM   #736
jeepbrattt
Have to wait til Monday to schedule with Howell. Troy wasn't working today. Off work til Monday, guess tomorrow since it's supposed to be 66 and sunny i'll clean and paint the jeep. Of course while listening to my new ipod setup ( sorry Jim.....some of us are still young at heart! )
Old April 30th, 2011, 10:46 PM   #737
MiNi Beast
MiNi Beast's Avatar
tru dat sista!
Old May 1st, 2011, 12:53 AM   #738
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Thanks Zac!!
you said junk.
H.o.r.e
Old May 1st, 2011, 08:13 AM   #739
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by bigbchevy View Post
you said junk.
LOL, I saw that.
She just keeps her junk in the trunk when she wheels.
@clarkstoncracker
Old May 1st, 2011, 08:18 AM   #740
jeepbrattt
you said junk.
LOL, I saw that.
I'm glad i'm not the only one that reverts back to a 4th grader when I read shit like this.
Page generated in 0.63688 seconds with 84 queries
