. - Page 36 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2011, 08:07 AM   #701
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Dang, sorry you have struggled so much. Would hate to know what you have into this conversion $$$$..
Fuk Cancer!!
RIP FULLSIZE4LIFE
Old April 28th, 2011, 08:19 AM   #702
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
99+ maybe....mines a 93
First computer he sent to me did not have a driver for drive by cable. All he had to do was open the case and look, he admitted he didn't. HIS FAULT
2nd computer may work for a newer 4l80E but NOT for a 93 or older. ( my 4l80 is a 93)I know when I talked to him I told him what everything was and what years.
ALSO....Kevin had to add wires to the harnass that Jim left off AND Tom has to change a few of them as well.
I paid Jim to do the job and gave him the info on what I was running, I absolutely put it in his lap. I paid the man to do the job because I can't. It's not like he messed up 1 thing. The entire job was botched. If I pay someone to do a job it is then THEIR responsabilty to do the research. NOT MINE. I commend his customer service, always have.....and I realize others sing his praises.........but I will NOT take the blame for lack of research when that's what i paid someone else to do. So you can take your high and mighty comments and get the fukc out of my build thread.
ZING!!!!
Old April 28th, 2011, 08:25 AM   #703
1TFROT
1TFROT's Avatar
I paid Jim to do the job and gave him the info on what I was running, I absolutely put it in his lap. I paid the man to do the job because I can't. It's not like he messed up 1 thing. The entire job was botched. If I pay someone to do a job it is then THEIR responsabilty to do the research. NOT MINE..........but I will NOT take the blame for lack of research when that's what i paid someone else to do.
I sooo feel your pain. I was in the same boat with mine. paid someone to get the whole swap correct and run the way I wanted it to and it was nothing but a nightmare when I got it back. had to pay another shop to make it right and I can now enjoy it.
good luck and keep your chin up. little more patience and you'll be good to go
1TFROT is offline   Reply With Quote
Old April 28th, 2011, 08:33 AM   #704
Please don't give her that encoragement. I'm trying to buy it off her cheap.
Old April 28th, 2011, 08:35 AM   #705
clarkstoncracker
lol
clarkstoncracker's Avatar
Yep, They checked that at the Badlands. All good
Pulling code po171......will get that all worked out with the tune
*** This is where she will be going to fix the computer issues. http://howellefi.com/
about time you took my advice, and stopped working with somebody out of state who could not physically work on your pos.
Old April 28th, 2011, 09:18 AM   #706
liv2mx
i like jungle gym's.
liv2mx's Avatar
alpine also makes some sweet decks..maybe a dvd w a flip up screen.
i have heard every day what is going on and jim's definetly did not take the time and do there job.
i keep telling her that everyone goes through this when doing a swap like she did..(everyone i know that has done this has had issues w something)it will work out.
tranny tom knows his shit and i hear the guys at howel know there's. so i am sure it will get figured out.
Old April 28th, 2011, 09:37 AM   #707
Truth hurts.
Old April 28th, 2011, 09:49 AM   #708
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
I wasn't aware that propane injection could shift transmissions..........hmmmmm I say go propane injection
99+4L80e is designed for the pcm OS your using, just sayin. Pretty unfair to blame Jim for your lack of research before sourcing parts IMO.
Really? They make full manual kits and stand alone controllers for the 4L80E. You'll have to do better than that. Hijack over.
Old April 28th, 2011, 09:50 AM   #709
Tom
Because racecar
Tom's Avatar
According to the casting number on the trans it is a 1993.
Beginning in 1994, the 4L80-E transmission was built with a new Force Motor (pressure control solenoid), new Spacer Plate, and they eliminated the torque signal compensator valve in the accumulator housing. The new force motor operates at the 614 Hz instead of the previous 292.5 Hz, which requires a different PCM program. With the new design force motor, the need for the cleaning cycle is eliminated, so the force motor is no longer pulsed every 10 seconds by the PCM/TCM. The case connector and wiring is the same for 1993 and up 4L80Es, so she is safe there and doesn't have to change any wiring.
The different force motor may be the issue that Becky is having with the trans. Also the 95-96 and up uses a nss which this one does not have. I also noticed no VSS wires on the t.case and no wiring on the t.case switch . The trans can use the output shaft speed sensor, but how is it going to shift in 4 low? I'm hoping Troy can make a program to run the earlier trans, if not, she may have to swap to a newer valve body or make this one full manual.
I'm still researching so don't freak out Becky.
Here are some pics I took last night to replace the tiny poopy ones in this thread.
Old April 28th, 2011, 09:54 AM   #710
Does she have those things?
I'm sure you'll love it once it's all worked out. Good tech in this thread, lots of my bs too so I'll stop now. Sorry for the inconvience.
Old April 28th, 2011, 09:59 AM   #711
liv2mx
liv2mx's Avatar
that was some info there tom.
Old April 28th, 2011, 11:19 AM   #712
Brian81CJ
Sellin' it all!
Brian81CJ's Avatar
Jackass!
It's not fixed yet, Tom's going to work his majic then I have to take it down to Troy in Marine City for the computer/tuning part. THEN......HOPEFULLY!!!!.......It will be all set.
Yes.......Fuck Cancer
Troy WILL get it straightened out for you!! He's a great Tech guy and Howell is a great company!! I've been working with them for years!!
Good luck!
Brian
Brian81CJ is offline   Reply With Quote
Old April 28th, 2011, 11:51 AM   #713
fabricator
throttle jockey
fabricator's Avatar
Attachment 78179
Attachment 78180
Attachment 78181
Attachment 78182
the whole t case speed sensor thing seems wierd to me. maybe tranny tom can shed some light on it. jims harness came back with no plug on the harness for the vss. when i asked him about it he said it is not needed on a 4l80e because it has two speed sensors on the trans. then he said there is a wire coming off the computer that can be grounded and it will change the shift points, but he says she would not need to do it. that was after he asked me the gear ratio and tire size.
fabricator is offline   Reply With Quote
Old April 28th, 2011, 12:07 PM   #714
Tom
Because racecar
Tom's Avatar
The 2wd version of the 4L80E uses the 2 speed sensors on the side of the trans and does not have a vss. The 4wd versions block the hole for the output sensor (with a dummy sensor), and use the output/vss sensor. When you are in 2wd high and 4wd high the ratio between the trans and t.case is 1:1. When you select 4 low, the ratio between the output of the trans and t.case change. If I remember correctly a 241 is 2.72:1 low range. So, the output of the trans is spinning faster (2.72 times faster) making the computer think it is going almost 3 times faster than it really is. This is where the 4 low switch and that wire Jim added comes into play.
*edit
I think I have seen some late model 4x4s use both speed sensors as well as a Vss but I could be wrong.
Old April 28th, 2011, 01:04 PM   #715
Bleay
sick of jackstand wheelin
Bleay's Avatar
*edit
You are correct, late model 4l80e uses input and output speed senors on the trans and VSS on the tcase.
Bleay is offline   Reply With Quote
Old April 28th, 2011, 02:40 PM   #716
jeepbrattt
New car smell.....Mmmmmmm
Talked to Tom, he is going to give Troy a call down at Howell and the 2 of them i'm sure will figure out the best route to go. This has been way more $$ ,time and stress then I signed up for..... but at least it's back at home now and everything is in working order.Sorting out the computer/trans issue is better then realizing the motor or trans is no good right? Im REALLY, REALLY trying to think "glass half full" over here. Thanks for the help guys.
jeepbrattt is offline   Reply With Quote
Old April 28th, 2011, 02:41 PM   #717
jeepbrattt
Do I need to come up there??!!
Old April 28th, 2011, 03:02 PM   #718
Mr. Beefy
BFT!
Mr. Beefy's Avatar
You'll get it Becky!
Can't wait to hear the pipes singing
Old April 28th, 2011, 03:17 PM   #719
jeepbrattt
I don't remember you chiming in when we were discussing where to go with the comp/harnass....
Old April 28th, 2011, 03:37 PM   #720
1TFROT
1TFROT's Avatar
my bad!
Page generated in 0.54228 seconds with 84 queries
