. - Page 34 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 26th, 2011, 06:20 PM   #661
Grassman
2jz specialist
Grassman's Avatar
none that dont involve a large hammer
Old April 26th, 2011, 08:11 PM   #662
jeepbrattt
New car smell.....Mmmmmmm
I'm almost to that point!
Talked to Kevin, he said Jimsperformance told him that plug is only needed to run back up lights on a 4l80. It plugs into a stock 4l80 shifter (which im not using. The wires that attach to it are coiled up by the back of the intake.
jeepbrattt is offline   Reply With Quote
Old April 26th, 2011, 09:44 PM   #663
jeepbrattt
I'd like to take the jeep in to a place that can hook it up to a laptop and tune it correctly. Anybody know of a good place?
Old April 26th, 2011, 09:46 PM   #664
Grassman
2jz specialist
Grassman's Avatar
chevy dealer
Old April 26th, 2011, 09:48 PM   #665
jeepbrattt
chevy dealer
sorry, I lost my sense of humor 3 pages ago.
Old April 26th, 2011, 09:52 PM   #666
BigTony
Rock Rebel
BigTony's Avatar
You need to have the PNP switch plugged in. Or wire a relay in, but I think I did that to unlock the torque converter.
Are you using a stock harness?
BigTony is offline   Reply With Quote
Old April 26th, 2011, 09:52 PM   #667
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
Pm Benny87 as he had a place local that was going or may have even did a tune on his....
NitzPixs is offline   Reply With Quote
Old April 26th, 2011, 10:00 PM   #668
jeepbrattt
No, Harness was from 2 seperate motors and redone at Jimsperformance.
There is no place to plug the pnp in on the trans. According to Kevin it plugged into the stock shifter. That's not what i'm using. Trannytom will be here tomorrow. I will ask him about that. Kevins just going by what Jimsperformance told him.
Old April 26th, 2011, 10:03 PM   #669
mschaffer66
mschaffer66's Avatar
I think Benny knows someone.
Old April 26th, 2011, 10:06 PM   #670
jeepbrattt
Sent him a pm.
Old April 27th, 2011, 05:11 AM   #671
John D
John D's Avatar
That does plug into the tranny just above the shifter lever. I wonder if your computer is looking for something from it, maybe the 4L80e sends something to the computer via another method.
Baker Engineering in Nunica. They did a friend's LS1 XJ and he was very happy. $250 for 5 pulls on the Dyno with tuning in-between each pull. He picked up 10 HP, 20 foot pounds torque and better mileage.
Old April 27th, 2011, 06:52 AM   #672
jeepbrattt
I was told it actually plugs into the stock shifter itself, which I don't have. I'll have Tom look, he'll be here tonite. Dale(ironman) and I both are thinking the same thing.......will see I guess.
I'll look them up , thanks!
Old April 27th, 2011, 07:32 AM   #673
Bleay
sick of jackstand wheelin
Bleay's Avatar
This is what the PNP plug should plug into. it will be on the d.s. of the trans where you connect the shifter to the trans.
Tranny Tom will figure it out for you.
Bleay is offline   Reply With Quote
Old April 27th, 2011, 07:33 AM   #674
fabricator
throttle jockey
fabricator's Avatar
there is a relay on the firewall right by the computer that is wired in to the brake light switch and is hooked to the trans via the computer. it uses a relay because it needs power all the time and gets turned off when you hit the brake pedal. just backwards of the stock brake switch.
fabricator is offline   Reply With Quote
Old April 27th, 2011, 07:35 AM   #675
fabricator
throttle jockey
fabricator's Avatar
yeah, her trans doesn't have anything like that. maybe because the trans is so old?
Old April 27th, 2011, 07:39 AM   #676
jeepbrattt
I have faith and my fingers crossed!
Aren't you glad it's not in your garage anymore? I'll let ya know what we find out tonite.
Old April 27th, 2011, 07:42 AM   #677
Bleay
Bleay's Avatar
[QUOTE=jeepbrattt;2637619]I have faith and my fingers crossed!
And if it has to come out, you know we can do that on a trailer anywhere without much sleep.
Old April 27th, 2011, 07:52 AM   #678
jeepbrattt
Sure do!!
That's what Dale was saying, there may need to be a switch replaced to adapt because of it being older.
Old April 27th, 2011, 08:16 AM   #679
Bleay
Bleay's Avatar
Did it look more like this: #711
Old April 27th, 2011, 05:12 PM   #680
jeepbrattt
Talked to Coreys hp tune guy in Marine City. He asked what motor and trans.I have. I told him '04 6.0 and a '93ish 4l80E. He asked if the computer was newer and set for drive by cable. Yes it is. His answer..."there's your problem" The 93 4l80 is a type specific trans. and will not work with the newer drive by cable computers. He said I need to use a stock computer and have it set it to pull no codes. He still wants Tom to look at the trans tonite before I bring it to him to make sure it is fully functioning and not part of the issue. Once that's done he can go over specifics with me and either make a program and computer for me to put in or bring it to him to put in and tune there.
I had Kevin call Jimsperformance this morning to pick his brain. When I called Jim back after talking to Coreys guy he said he hadn't even talked to Kevin and had no idea why the 93 would be any different. Regardless he agreed to send the $200 back that he charged for the computer.
So after Tom checks it out tonite I will call the new place back and give him the findings and figure out the game plan. Probably will just trailer it down there to have him do it all so I won't have to worry. Wish I knew about this guy first but at least we are on the right track now.
Page generated in 0.39357 seconds with 84 queries
