. - Page 33 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2011, 06:05 PM   #641
Tom
Because racecar
Tom's Avatar
Me thinks trans is in limp mode. Do you feel the trans shift at all? It sounds like it is taking of in third gear which would explain the no power in 2wd and power in 4 low.
Old April 25th, 2011, 06:34 PM   #642
jeepbrattt
New car smell.....Mmmmmmm
I did feel it shift at Badlands, shifted hard, honestly don't remember noticing it shift today. How do I fix that?
jeepbrattt is offline   Reply With Quote
Old April 25th, 2011, 06:35 PM   #643
BigTony
Rock Rebel
BigTony's Avatar
I agree, I think your on to something.
Becky does it shift at all?
BigTony is offline   Reply With Quote
Old April 25th, 2011, 06:45 PM   #644
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Are you burning the tires in 2wd?
Old April 25th, 2011, 06:50 PM   #645
jeepbrattt
Taking it for a spin.....be right back
Old April 25th, 2011, 07:00 PM   #646
jeepbrattt
Took it ror for a ride. In 2 wheel drive it did not shift at all and never got enough power to even try, in 4 low it shifted only once, so im guessing 3rd into overdrive. I can manually shift it and it's a whole diff animal. Wants to launch.
What's the fix?
Old April 25th, 2011, 07:06 PM   #647
Are you set up with a manual valve body and must always shift it manually?
Old April 25th, 2011, 07:17 PM   #648
jeepbrattt
hope not. thats not what i wanted.
Old April 25th, 2011, 07:20 PM   #649
Tom
Because racecar
Tom's Avatar
For some reason there is no power going to the trans. It needs to be scanned and checked for power.
Old April 25th, 2011, 07:21 PM   #650
bbaXJ
Yooper In Training
bbaXJ's Avatar
Was told it was a stock rebuild with about 500 miles on it when I bought it. Maybe a shift kit at the most(he wasn't sure, it was his dad's) but definitely not full manual.
Old April 25th, 2011, 07:23 PM   #651
jeepbrattt
thanks sean
Old April 25th, 2011, 07:24 PM   #652
jeepbrattt
anyone have a scanner they can stop by with?
Old April 25th, 2011, 07:25 PM   #653
bbaXJ
Yooper In Training
bbaXJ's Avatar
No problem, I hope it gets working for ya soon!
Old April 25th, 2011, 07:47 PM   #654
jeepbrattt
scanner will be here tomorrow afternoon
Old April 26th, 2011, 11:15 AM   #655
fabricator
throttle jockey
fabricator's Avatar
the 4l80e has 2 speed sensors on the trans. 1 in the front half of the case and 1 in the rear half. they are 2 wire plugs and i think they are purple. make sure they are both plugged in and didn't get knocked out when they were doing the exhaust. i think the 4l80 is the only trans with the 2 speed sensors. i believe the 4l60s need the speed sensor from the t case also.
fabricator is offline   Reply With Quote
Old April 26th, 2011, 12:34 PM   #656
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Just wanted to point out that there are like 8 pictures in this thread with 753 posts
Old April 26th, 2011, 04:05 PM   #657
jeepbrattt
hecked, thay are conected. The front one has wires that are laying damn near on the linkage, don't know if that may be an issue.
Ok smart ass...here's another pic for ya.
This was the only plug I found that wasn't connected to anything around the trans. Anything? Or is this where a scanner hooks to check for issues?
Old April 26th, 2011, 04:11 PM   #658
Cool parts peddler
Ironman Offroad's Avatar
Says PnP switch.
Should be park/Nuetral Position Switch located on left side of the transmission. PCM does not know what you want it to do!!!!!
Old April 26th, 2011, 04:13 PM   #659
jeepbrattt
Says PnP switch.
Got under it to see if the plugs Kevin mentioned were hooked. Also was a round larger plug between the two connected. Looked around and saw this. So I need to find where this plugs in directly on the trans right?
Old April 26th, 2011, 04:43 PM   #660
jeepbrattt
Couldn't see anyplace where this would plug in, altho I couldn't see alot with the skid and everything else in the way. Thanks for the call Dale!
Thinking maybe switch needs to be changed? Motor is 04, trans Sean guessed around 93. Ideas?
Page generated in 0.34055 seconds with 84 queries
