. - Page 32 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2011, 06:06 PM   #621
jeepbrattt
New car smell.....Mmmmmmm
New computer is flashed and on it's way to me.
Can everyone just keep their fingers crossed that all goes well please!!??
jeepbrattt is offline   Reply With Quote
Old April 21st, 2011, 06:26 PM   #622
pass45
pass45's Avatar
glad to see you found what was wrong
pass45 is offline   Reply With Quote
Old April 21st, 2011, 06:30 PM   #623
jeepbrattt
Hey! You found the site
Hopefully all goes well when I hook it up. Gotta change the plugs and oil and put the IAC back where it was. Then pray!!!
USPS says should be here Monday.
Old April 21st, 2011, 06:42 PM   #624
pass45
pass45's Avatar
it will be fine it just takes some time to get the bugs all worked out but it's worth it
Old April 21st, 2011, 10:01 PM   #625
MiNi Beast
MiNi Beast's Avatar
fingers crossed
Old April 23rd, 2011, 10:44 AM   #626
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Did he say anything about the O2 sensors?
I'm late to the game here, but I think the only thing you have to worry about is how the calibration assigns the sensors WRT the pins at the ECU. Think of it as a set of SW dip switches to define what input should be read as what sensor location.
@clarkstoncracker
Old April 25th, 2011, 03:50 PM   #627
jeepbrattt
Got the new computer today, changed the spark plugs and started her up. Idles at a nice level now. Much better. Let it run for about 10 minutes and took it up and down the street. in the rain, got some funny looks from the neighbors. Yep..no top.
Seems a ton better, but not real responsive on the shifting. Tranny may need fluid, will check. Oil needs to be changed too. Still missing and hesitating every once in awhile.
Will just letting it sit and idle help? 20 minutes maybe?
Old April 25th, 2011, 03:51 PM   #628
I can understand why you got looks with no top.
No, letting it sit won't help the shifting. Check your trans fluid, that's probably it.
If the engine is running rough, yes, let it run but I doubt it will help.
Old April 25th, 2011, 03:55 PM   #629
jeepbrattt
Well I know letting it run won't help the shifting.
Its running fine at idle, more of a response time when i hit the gas. Sputters once in awhile.....i know the oil has some gas in it from when we were messing with it at Badlands.
Old April 25th, 2011, 03:59 PM   #630
If the oil has gas in it, get that out of there. Too much will destroy the bearings. Learned that the hard way with a badly flooded motor at the mounds
Old April 25th, 2011, 04:01 PM   #631
jeepbrattt
Guess i wont let it run then. Get that done before i mess with anything else
Old April 25th, 2011, 04:04 PM   #632
Might be fine, just depends on how much is in there. Mine had a lot enough to read high on the dipstick. It killed my bearings and valve seals.
Don't know much about the electronic 4 speeds. For the running rough, have you tried pulling codes again?
Old April 25th, 2011, 04:05 PM   #633
jeepbrattt
Not yet, seriously just hooked the computer up maybe an hour ago. No gas on the dipstick....i looked
Checked trans fluid, way low. Have to run to the store.
Old April 25th, 2011, 06:03 PM   #634
jeepbrattt
Ok, checked and topped off all fluids, changed plugs. Motor idles/revs nice. When on the road in 4x4 seems peppy and more responsive( not perfect tho). Take it out of 4x4 and it has issues. Hard to describe, just doesnt go anywhere. revs, thats about it. weird. I think I need some drive train guru to come take it for a test drive and see what ya think. I'm at a loss.......
Old April 25th, 2011, 06:09 PM   #635
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
Did you screw the Idle Air Control Valve back in?
samurai2240 is offline   Reply With Quote
Old April 25th, 2011, 06:11 PM   #636
samurai2240
Also are you putting it in 4 low. or 4 high.
Old April 25th, 2011, 06:16 PM   #637
jeepbrattt
shit, forgot about that. That wouldn't make a diff in how it acts in or out of 4x4 tho would it?
The shifter is now backwards of what it was originally, so all the way up is 2 wheel drive. All the way down would then be 4 low correct? Those are the only 2 positions I drove it in.
Old April 25th, 2011, 06:27 PM   #638
samurai2240
4 low will make it fill like it has more power that any other gear.
Old April 25th, 2011, 06:31 PM   #639
samurai2240
Their are two screws on the idle air valve (allen head) that you have to take out to access the valve. Then you can screw it back in.
Old April 25th, 2011, 06:59 PM   #640
How is your VSS setup? Thats one thing that no one seems to have a great way to do. The factory system changed the shift points based on high or low. Lot of people have issues with shift points, depending on if they have the vss in the adapter or in the tailhousing, and if they have the inputs back to the computer on if its high or low range.
lol, this is why I stuck with a th350.
Page generated in 0.43661 seconds with 84 queries
