. - Page 31 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2011, 01:10 PM   #601
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
If you are converting a motor from drive by wire to cable make sure the circled area on the top left have the prongs. (location on a 2605 anyway)
See how easy that would have been to check, 4 bolts .......
Who did you get to remove the four bolts for you....
Old April 18th, 2011, 01:15 PM   #602
jeepbrattt
New car smell.....Mmmmmmm
hmmmmmmmmmmmmmmm...........
First gir's rig build on the forum.
First mistake by Jim I have ever heard of.
Coincidence?
Sorry Becky....... I had to.
Yea....I was waiting for that!
I did that all by myself!
(however i'm having a hell of a time trying to get the harness to disconnect )
jeepbrattt is offline   Reply With Quote
Old April 18th, 2011, 01:33 PM   #603
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
Also remember to screw the Idle Air Control Valve back in. Good luck.
samurai2240 is offline   Reply With Quote
Old April 18th, 2011, 01:37 PM   #604
jeepbrattt
Will do Thanks for all your help this weekend Ronnie!
Old April 18th, 2011, 04:11 PM   #605
John D
John D's Avatar
Ok, here's the problem.......the computer I have does not even have the IAC driver. Talked to Jim this morning, popped the cover off the computer, where there's supposed to be prongs for this, there aren't. Apparently this is a first for him and this computer # will now be put to the list to be checked before flashing. Unfortunatly it happened at my expence. Regardless the computer I sent would not have worked, wish he would have opened the cover tho.
Why were/are you anti-DBW?
How would you check the computer and harness together? You think he has a bench stand setup with every year/sensor/wiring combo out there to magically plug in and tell him everything is working?
X2
Unfortunately there just is no good way to test until you put it all together. Remember you paid ~$300 to have the harness built/modified, not $600. There is only so much someone can/will do for a given amount of money.
Coincidence?
Now that's funny!
Glad you are on track to a resolution. It will be worth all the hassles... eventually.
Old April 18th, 2011, 04:19 PM   #606
It's easy to play monday morning quarterback but you don't even understand the game of football in this instance so critiquing should probably be kept to a minimum IMO. How would you check the computer and harness together? You think he has a bench stand setup with every year/sensor/wiring combo out there to magically plug in and tell him everything is working? Glad to hear it's getting taken care of. It sounds like an honest mistake to me though. I'll still be sending my harness to Jim, I won't even bother to hassle with it for what he charges.
Well, in my case, he specifically told me that he fired up my harness, TAC module, pedal, and harness and it all was good. So I wonder in her case what he did.....
But I'm also DBW.....
Old April 18th, 2011, 04:56 PM   #607
Grassman
2jz specialist
Grassman's Avatar
then it sounds like he could have tested the harness to a certian degree for becky too then
Old April 18th, 2011, 05:10 PM   #608
jeepbrattt
We switched my motor from wire to cable. He knew the motor WAS by wire and being adapted to cable. That's why I say he should have opened the case and looked for the driver. It's very simple, he told me right where to look and I knew it wasnt there.....that's my biggest issue. (and the fact 2 wires were missing from harness that Kevin had to pull off one of his and add)
He told Kevin he tests EVERY computer/harness combo before shipping them back. Don't see how that possibly happened.
Old April 18th, 2011, 05:14 PM   #609
jeepbrattt
X2
Unfortunately there just is no good way to test until you put it all together. Remember you paid ~$300 to have the harness built/modified, not $600. There is only so much someone can/will do for a given amount of money..
Rest of the set up wasnt there for DBW....cheaper to adapt, and had many tell me the cable was the better route
Also, not bashing him. I'm just saying IN THIS CASE he skipped a VERY important step on my computer.
I paid 370 for the harness....if you cant/wont do it right for that amount, raise your price
Old April 18th, 2011, 05:15 PM   #610
MiNi Beast
MiNi Beast's Avatar
tits or gtfh!
Old April 18th, 2011, 06:04 PM   #611
I was anti DBW...................... until I did it. Wow! Simple, instant response time, I like it.
Old April 18th, 2011, 06:11 PM   #612
John D
John D's Avatar
I've heard this before too, still don't understand it though. Never had anything go wrong with or had any negative drivability issues with my DBW. I know your case is different because you didn't have all the parts, but for anyone else considering it I think it's poor advice.
Fair enough if that's what you were led to believe was going to happen. I am still surprised that someone will put that much work into a harness plus have the the set-up to test all the duifferent configurations for $300-something.
Old April 18th, 2011, 07:28 PM   #613
jeepbrattt
Got an email from Jim.....he has purchased a 6106 that from what he says is DBC and interchangable with the 2605. He will flash that as soon as he gets it and send it over. I sent the old one back so he gets a core out of the deal. Let's hope this is the end of this unfortunate lesson and we can move on to seeing how well I can adapt to the new found hp.
Old April 18th, 2011, 11:35 PM   #614
BigTony
Rock Rebel
BigTony's Avatar
Bad computer flash Drove it on the trailer and took off without any time to do a test run to check everything out. Got to the Badlands, pulled it off the trailer and she was ok at best when cold, as soon as she got warmed up the idle was all over the place. Took a short run around campground and was missing like crazy and backfiring. Every once in awhile she would catch and I got a slight taste of the power that will be there. Guy at the campground had a scanner, ran a couple codes. po171 and po103. One is a lean code the other MAF. After swapping out the sensor with another like built rig that was eliminated, no vacuum leaks either. Called Jimsperformance, he walked us thru a couple tests with other sensors, all comes back to a bad flash. Jim was as much help as he could be without us having a laptop to communicate with him. We believe it wasnt flashed for drive by cable (motor was originally drive by wire). Not real happy about that because description was all written and sent along. So tomorrow the computer goes back.
We hopped in other rigs and salvaged the weekend, still had a great time despite that and the shitty weather. My kid did her first rock climb in Kevins buggy up about a 7' ledge......made it all worth it.
Glad to here you got this worked out.
BigTony is offline   Reply With Quote
Old April 19th, 2011, 06:19 AM   #615
jeepbrattt
Hopefully, Thanks Tony and nice wheelin with ya again!
Old April 19th, 2011, 11:33 AM   #616
liv2mx
i like jungle gym's.
liv2mx's Avatar
you were wheeling???? driving up and down the road does not count..
from what i was told the drive by wire is good until you dip it in a water hole..that is why most guys switch it to dbc. i don't know too many people that have done one of these swaps and not had little issues..that is why i asked if it was driven around and tested.oh well a bad day of wheeling is still better then a good day at work!!
Old April 19th, 2011, 11:59 AM   #617
That was my big arguement. However, since your MAP, MAF and ECM are all electric, all of them are a problem if they get wet and you have to be careful about stuffing your nose in a deep hole. YES, the DBW module is lower but come on, you have to be in almost 4 ft of water to be an issue. It's not sitting right on your floorboard. I've had water over my tires & not gotten my module wet. With that, I picked up a spare module for about $20.
Old April 19th, 2011, 12:10 PM   #618
mschaffer66
mschaffer66's Avatar
yfrom what i was told the drive by wire is good until you dip it in a water hole..that is why most guys switch it to dbc.
To me it seems like if the water is deep enough to get the DBW wet, shorting that out is the least of your worries.
Old April 19th, 2011, 12:15 PM   #619
Porter
Porter's Avatar
Default Hmmmmm
Bummer Becky.
Puters make engines better in some ways, but suck in others.
Glad you figured it out.
Dirty Minds Jeep Club
DMJC WEBSITE
Originally Posted by Twilight View Post
so yeah what Ross said...
Porter is offline   Reply With Quote
Old April 19th, 2011, 10:33 PM   #620
Yep, I was concerned...until I looked where it mounts. Its about on part with my valve covers. I'd likely hydrolock the motor first...
Page generated in 0.51351 seconds with 84 queries
