. - Page 28 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2011, 07:59 PM   #541
frdboy
frdboy's Avatar
Originally Posted by fabricator View Post
ok. trying to help becky finish this thing without having to spend a bunch more cash. all it needs is o2 sensors. heres the problem, the wire harness we are using is from an 05. it has a triangular shaped plug for the o2 sensors. they are both the same. in the box of parts she got with the motor was some foot long peices of down pipes that look like they bolt on the exhaust manifolds. they both have o2 sensors in them. they are square plug ins. one has a female plug on it and the other has a male plug on it. they will plug into each other. just went and looked at a harness my buddy has and was gonna steal the plug ins off from, but it has male plug ins for all 4 o2 sensors pre and post cat. not sure how she has a male and female sensor? starting to think these sensors arn't even for an ls motor? probably be best just to buy 2 new ones that fit the current harness?
I would just get new ones, who knows if the others are even any good and if they are bad can really make those motors run bad.
Old April 13th, 2011, 08:06 PM   #542
MiNi Beast
MiNi Beast's Avatar
http://www.autozone.com/autozone/par...er=596607_0_0_
Bosch/Oxygen Sensor
For your 2005 Chevrolet Truck Silverado 3500 4WD 6.0L SFI 8cyl
Price:
$93.99
Part Number: 15282
order today have by thursday
1236 E APPLE AVE
MUSKEGON, MI 49442
(231) 773-4479
Old April 13th, 2011, 08:07 PM   #543
It's not a weekend stopper. She can run open loop and all that will happen is she will probably run rich.
Old April 13th, 2011, 08:12 PM   #544
MiNi Beast
MiNi Beast's Avatar
upstream o2s D/P are triangle. downstream O2s D/P are square
Old April 13th, 2011, 08:18 PM   #545
frdboy
frdboy's Avatar
Sure if it outright fails or you unplug it but I have seen those stick high and the pcm pulls so much fuel cuz it thinks it is rich that it will cause it to mis on that bank, all 4 cyls.
Old April 13th, 2011, 09:14 PM   #546
Originally Posted by High Center Hancho View Post
wat? you do not need oxygen to travel through the insulation...I have changed ends on O2 sensors and soldered and heat shirked them with no problems
Not through the insulation, through the strands of the wires themselves. An O2 sensor works by 'comparing' (keeping things simple) the oxygen level within the gas stream to reference air. The reference air is supplied to the sensor through the strands of some of the wires themselves. Because its the method thats less likely to be plugged up, than say, a port on the side of the sensor exposed to the elements..
So you do need to be careful with those wires. The OEMs normally don't recommend any type of wire repair on them. Some people it works fine, some it doesn't work fine. So as a rule, you try not to seal those strands if you mess with them.
Dammit, I just checked my harness. I've got two triangle plugs on my harness. Checked my mainfolds, one male, one female, both square. dammit..
Old April 13th, 2011, 09:26 PM   #547
jeepbrattt
New car smell.....Mmmmmmm
[QUOTE=Haggar;2620884]Not through the insulation, through the strands of the wires themselves. An O2 sensor works by 'comparing' (keeping things simple) the oxygen level within the gas stream to reference air. The reference air is supplied to the sensor through the strands of some of the wires themselves. Because its the method thats less likely to be plugged up, than say, a port on the side of the sensor exposed to the elements..
Dammit, I just checked my harness. I've got two triangle plugs on my harness. Checked my mainfolds, one male, one female, both square. dammit..[/QUOTE]
Well...plan on $200 bucks! Welcome to my world!
jeepbrattt is offline   Reply With Quote
Old April 14th, 2011, 07:11 AM   #548
Yep... I found tghat the wrecking yard also switched my alternator to a 2004 unit...plug is different than my 2007 harness...another 150 bucks....
Old April 14th, 2011, 07:13 AM   #549
MiNi Beast
MiNi Beast's Avatar
but its all the same. gotta love the junk yards and part swapping.
Old April 14th, 2011, 07:53 AM   #550
Yeah, Jim's performance loved me. The TAC module and ECU were mismatches too.
Old April 14th, 2011, 08:01 AM   #551
jeepbrattt
We sent him half of 2 diff harnesses. Im sure he liked that too.
Sucks I have to have these parts today, Roger is right, $93 per. Amazon has them for $60 and rockauto $70.......parts stores wont pricematch online....i checked, oriellys , auto zone and napa. So $180 plus tax.......son of a bitch!
Old April 14th, 2011, 08:08 AM   #552
MiNi Beast
MiNi Beast's Avatar
I have a coupon for like $20 off at advance
Old April 14th, 2011, 08:22 AM   #553
chevotass
chevotass's Avatar
i just bought my headgasket on advanced autos website. they have a promo right now. go sign up and order them and pick up in store you should get $25 off that purchase i think. i saved $10 this morning doing that over going into the store to do it. heading out to pick it up now.
Old April 14th, 2011, 08:23 AM   #554
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Becky pm me the part numbers you need and ill check my hook up here in town. If i can get them for the online price i will and run them to Kevin.
Old April 14th, 2011, 08:26 AM   #555
Porter
Porter's Avatar
Default Hmmmmmmmm
I like my O2 sensor.......its the screw on the side of the Holley Carb
The computer is me!........except its a bit outdated and runs in DOS
The couple hundred dollar things always kill ya in any project.
Going to be cool when yer done Becky
Dirty Minds Jeep Club
DMJC WEBSITE
Originally Posted by Twilight View Post
so yeah what Ross said...
Porter is offline   Reply With Quote
Old April 14th, 2011, 08:26 AM   #556
chevotass
chevotass's Avatar
www.advanceautoparts.com $25 off
Old April 14th, 2011, 08:27 AM   #557
chevotass
chevotass's Avatar
have an extra mass air sensor laying around from your project? i need one for my 307 van motor
Old April 14th, 2011, 08:29 AM   #558
MiNi Beast
MiNi Beast's Avatar
Bosch/Oxygen Sensor
Price:
$93.99
Part Number: 15282
1236 E APPLE AVE
MUSKEGON, MI 49442
(231) 773-4479
here you go Collin
Old April 14th, 2011, 09:12 AM   #559
The big MAF that goes in front of the throttle body? I have a spare I think...
Old April 14th, 2011, 09:46 AM   #560
chevotass
chevotass's Avatar
yah. i need the big maf that goes on the intake tube in front of the throttle body
Page generated in 0.44065 seconds with 84 queries
