. - Page 27 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2011, 08:37 AM   #521
What did you do for oil control?
Old April 13th, 2011, 08:50 AM   #522
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
No, we still plan on staying at your place Thurs night. Then to Badlands in the am.
Exhaust was an absolute nightmare.....after all the research on mufflers I ended up not using the Spintechs. There was so little room under there that they ended up having to do a 2 into 1 , single out on the passenger side. They ran a few ideas by me for the duals but this ended up to be the best option. Really....just glad it's done. Kevin will be putting the exhaust sensors in tonite and see how she sounds, runs and shifts. Hopefully all will be good and he will have time to build the bumpstops up a bit for me.
No room on the passengers side right? Did they end up using a SS muffler, I like mine. It is quieter than planned but, I like it now. How/where did they cross the drivers side over? We had to go in front of the oil pan sump on mine.
RIP FULLSIZE4LIFE
Old April 13th, 2011, 09:34 AM   #523
liv2mx
i like jungle gym's.
liv2mx's Avatar
we are leaving late thursday night. meeting mike steele at mike r's house in zeeland. then going from there.
Old April 13th, 2011, 12:14 PM   #524
jeepbrattt
New car smell.....Mmmmmmm
I haven't seen it yet, but this is what I was told was done.
jeepbrattt is offline   Reply With Quote
Old April 13th, 2011, 12:26 PM   #525
jeepbrattt
Nothing special, running the stock pan for now, will see how the pressure is this weekend, if it's an issue I will upgrade.
Old April 13th, 2011, 12:54 PM   #526
FYI, look at our Moab trip. I never lost oil pressure on any of those inclines using my stock corvette pan. And quite frankly, I don't want to get any steeper.
You will note in one of the early pics I stated that I found the point where I lost oil pressure. Come to find out, I was a pint low.
Old April 13th, 2011, 01:26 PM   #527
Do you know which vette pan you have, Jim? Its the C6 LS2 pan? Not a C5 batwing....
I think I will use that also.
Old April 13th, 2011, 01:45 PM   #528
I'm not sure. We should let Bryce weigh in.
Old April 13th, 2011, 02:12 PM   #529
I heard he sold his stuff and was building a Honda Civic now....
Old April 13th, 2011, 02:13 PM   #530
or crawl under and read the GM part number thats likely stamped into it...
Old April 13th, 2011, 03:10 PM   #531
You're asking a lot there buddy.
Old April 13th, 2011, 03:11 PM   #532
John D
John D's Avatar
If it helps his case any, I would like to know too :)
Old April 13th, 2011, 04:42 PM   #533
jeepbrattt
02 sensor issue is this.....sensors are the square plugs, harness has the triangular plug. He will figure it out, either new sensors or swap the harness piece.
Old April 13th, 2011, 04:56 PM   #534
drew91xj
drew91xj's Avatar
huh the old saying you cant put a sqare part in a round holds true lol... hope you guys get if figured out, and have a good time in attica
Old April 13th, 2011, 04:57 PM   #535
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
BS!
You're not using a big enough hammer.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old April 13th, 2011, 04:57 PM   #536
And there were two types of square plugs too, one for 05, one for 06/07.
If you swap the plugs, do NOT solder and heat shrink them. If you must splice, you a crimp connector. You need to have oxygen to be able to travel in the line..
Old April 13th, 2011, 08:27 PM   #537
fabricator
throttle jockey
fabricator's Avatar
ok. trying to help becky finish this thing without having to spend a bunch more cash. all it needs is o2 sensors. heres the problem, the wire harness we are using is from an 05. it has a triangular shaped plug for the o2 sensors. they are both the same. in the box of parts she got with the motor was some foot long peices of down pipes that look like they bolt on the exhaust manifolds. they both have o2 sensors in them. they are square plug ins. one has a female plug on it and the other has a male plug on it. they will plug into each other. just went and looked at a harness my buddy has and was gonna steal the plug ins off from, but it has male plug ins for all 4 o2 sensors pre and post cat. not sure how she has a male and female sensor? starting to think these sensors arn't even for an ls motor? probably be best just to buy 2 new ones that fit the current harness?
fabricator is offline   Reply With Quote
Old April 13th, 2011, 08:56 PM   #538
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
wat? you do not need oxygen to travel through the insulation...I have changed ends on O2 sensors and soldered and heat shirked them with no problems
Old April 13th, 2011, 08:58 PM   #539
MiNi Beast
MiNi Beast's Avatar
So the problem is the sensors themselves or the harness connector? Harness has original o2 plugs right... so then I would say just buy 2 new ones that match the harness. right?
Old April 13th, 2011, 08:59 PM   #540
MusKegon_ZJ_gurl
That is because you are "High Center Hancho" it will not work for anyone else.
Page generated in 0.50979 seconds with 84 queries
