. - Page 18 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2011, 06:37 PM   #341
crosseyed cat
safety cone killer !!!
crosseyed cat's Avatar
I hope you make DP2 i am not going to make it i think its erins falt
crosseyed cat is offline   Reply With Quote
Old March 10th, 2011, 07:42 PM   #342
jeepbrattt
New car smell.....Mmmmmmm
Not gonna make it either Corey. Will be in the garage with Kevin figuring out placement of shifters tho. If all goes well should be running by then too, just lots of little thing to button up at that point. It's gettin there
Yea, i'd blame Erin if I were you!
jeepbrattt is offline   Reply With Quote
Old March 15th, 2011, 07:49 PM   #343
jeepbrattt
Mass air sensor all hooked up.
next is getting the fuel lines all set.
Old March 15th, 2011, 07:56 PM   #344
jhnyquest
goof ball
jhnyquest's Avatar
Looking good.
Old March 18th, 2011, 05:49 AM   #345
jeepbrattt
All the sensors are now hooked up, had to go on a scavenger hunt for misc screws but all good. Fuel pump, filter and lines all ran, except return line....
Old March 18th, 2011, 06:08 AM   #346
Heroux
caveman
Heroux's Avatar
Default jeep
looks great
Heroux is offline   Reply With Quote
Old March 18th, 2011, 07:16 AM   #347
John D
John D's Avatar
What are you doing for transmission lines? I am tired of my seeping/dripping lines and I am curious what you are doing and what others have done.
Old March 18th, 2011, 07:26 AM   #348
jeepbrattt
I'll be over there Sunday...will see what Kevin has done. try and get some more pics up.
Old March 18th, 2011, 07:31 AM   #349
jeepbrattt
Have a question for you guys.......
How is everyone running the return fuel lines when using a stock TJ gastank? The tank has no spot for a return line.
Do we just get a fitting and drill a hole in top of the tank?
Old March 18th, 2011, 08:15 AM   #350
I have flared fittings at the trans and hose barbs at the trans cooler. Yeah, you need to tighten them time to time.
Sort of. you need to pull the plate that holds the pump and pickup. Drill a hole through it with bulkhead fittings, then put a tube almost to the bottom. This way the returning fuel doesn't splatter around and make noise/turbulance. Under the plate but at the top of the tube you drill a small (small as possible) hole for anti siphon.
Old March 18th, 2011, 10:57 AM   #351
John D
John D's Avatar
What are the flared fittings? Where do you get them?
X2 on the fuel return location, but I let mine splash around; so far so good.
Old March 18th, 2011, 12:25 PM   #352
I have a TH350 trans that has a flared fitting on each port. (out and return) A standard flared bundy tube bolts right up. Then use a fitting at the other end that adapts to a barbed fitting, attach short section of hose and you are done. Go to your local auto parts where they have the rack of pre-flared brake lines. Get the 5/16 or 3/8 size.
Old March 18th, 2011, 02:09 PM   #353
John D
John D's Avatar
Ah yes, TH350. I guess that makes it easy, 4L60e here...
Old March 18th, 2011, 02:23 PM   #354
The TH350 and 4L60e should both be 1/4 in.-18 NPSM with straight threads. Maybe some early TH350s were tapered.
THe factory jobs on Jim's trans go from the straight pipe thread to a flare fitting. You can get them to go to AN lines also...
Old March 19th, 2011, 03:30 PM   #355
jeepbrattt
Old shifters are now tore out. Would be listening to it run right now if he knew if there were oil in it....but the dipstick tube is in my truck...
Heading that way tomorow.....can't wait!!!
Old March 20th, 2011, 11:07 AM   #356
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
getting close, looking good
Old March 20th, 2011, 12:40 PM   #357
MiNi Beast
MiNi Beast's Avatar
It runs, IT RUNS!
Old March 20th, 2011, 04:05 PM   #358
jeepbrattt
Yes Roger it RUNS!!!!
After all the issues this swap has had it finally runs. Started up extremely easy. Now it's just a matter of putting the little pieces back together and final touches.
Figured out where the shifter needs to be, although Kevin will be changing the handle to about twice the length. Gauges will be placed where the ashtray and old ARB switches are and an engine skid will be added so I don't do a repeat of last labor day...
Going to run dual exhaust......need to find a shop or someone who does a great job at that somewhat local to me. Anyone???
Can't wait to bring her home
Old March 20th, 2011, 04:31 PM   #359
drew91xj
drew91xj's Avatar
good to hear
Old March 20th, 2011, 04:41 PM   #360
chevotass
chevotass's Avatar
id have to ask around. but there used to be a guy in waterford that did custom exhaust for good prices. montys place i think was the name.
Page generated in 0.37555 seconds with 84 queries
