. - Page 16 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 18th, 2011, 10:14 AM   #301
jeepbrattt
New car smell.....Mmmmmmm
I have a Hurst shifter mounted directly between my seats so it's a natural location without having to lean to reach it. I modified my gates so I have a smooth motion between R-N-D. No clicky, lifting a trigger or anything. It's extreamly nice to be able to slam reverse from drive when things get hairy.
This would be the only way I would buy gated, to modify it. And after it was mentioned earlir, I agree, no levers or triggers to lift is better
jeepbrattt is offline   Reply With Quote
Old February 18th, 2011, 10:15 AM   #302
liv2mx
i like jungle gym's.
liv2mx's Avatar
jim is real old so you know he has to have something comfortable, since those bones of his don't move real fast.
Old February 18th, 2011, 10:15 AM   #303
jeepbrattt
Originally Posted by liv2mx View Post
you need to sit in your jeep and measure from the floor up and see how long of a handle you need. i was thinking the adjustable 16" so you could mount it were it felt comfortable. but yes that might be too long of a handle.you need to measure it to be sure..this is a real important part to fit you perfect..
My thoughts exactly
Old February 18th, 2011, 10:22 AM   #304
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i think we need to take in account the brain cells erin has cooked over the years before we listen to him
Old February 18th, 2011, 10:30 AM   #305
The Art Carrs had some nice off-road gates for some models that allowed the shift from 1st to R without any gates.
I've not heard of anyone liking the Lokar for that style, there's nothing to let you shift to R to avoid a roll, without accidentally hitting some other gear.
Get one like the pro stick, and grind out the gates like everyone does. BillaVista has a big detailed article on it. I will set mine so that shoving all the way forward is reverse, shoving all the way forward when pulling the trigger is neutral.
Old February 18th, 2011, 10:36 AM   #306
jeepbrattt
http://www.racereadyproducts.com/aut...awler-shifter/
Just found this on pirate...what do you think???
Actually cheaper then Lokar as well because lokar does not include cable or boot with their shifters in most cases. Didn't see mention of one for a 4l80 tho
Old February 18th, 2011, 10:37 AM   #307
liv2mx
liv2mx's Avatar
don't you have a baby jeep to work on....
she definetly needs something that is easy to use.as long as the gates are ground out that might be an option.
Old February 18th, 2011, 10:43 AM   #308
problem is you have a 4 speed and a standard forward valve body.
Old February 18th, 2011, 11:36 AM   #309
benny87
Young Gun..!
benny87's Avatar
I have an art-carr with a nodified gate from RN2 sense I do most of driving in 2nd its a quick flip to R.
benny87 is offline   Reply With Quote
Old February 18th, 2011, 11:49 AM   #310
Bleay
sick of jackstand wheelin
Bleay's Avatar
Cover......part # 12577903
Gasket....part # 125532190
At the dealer. I looked elsewhere, the shipping was more then the part.
need the oil dipstick tube and stick as well
tube.....part # 12570623
stick.... part # 12570788
Do you still need these parts?
Bleay is offline   Reply With Quote
Old February 18th, 2011, 12:16 PM   #311
jeepbrattt
yes, havent ordered them yet
Old February 18th, 2011, 12:25 PM   #312
jeepbrattt
i like the winters shifters
looked into them, couldn't find a single 1 for a 4l80. same for the Hurst.
looks like http://www.summitracing.com/parts/BMM-80706/ like Hag gar recommends and cut the gates, or go with Lokar. Not making a decision today, still looking for options.
Old February 18th, 2011, 12:29 PM   #313
hosejockey4506
Visiting Admin
i think you just have to use a 700r4 shifter, but im not sure
i know people who are using them but there running full manual valve bodies but i dont think that makes a difference
Old February 18th, 2011, 01:39 PM   #314
jeepbrattt
oil cooler, distick tube being picked up at dealership Tuesday.
Jimsperformance just called too......harnass is done.
Aahhhhhhhhhhhhhhhhhh...progress
Old February 18th, 2011, 03:04 PM   #315
95geo
newbie
95geo's Avatar
A shifter for a 700r4 should work on a 4L80. The detents are the same between them. For what it's worth, I'm using a TH400 shifter on a 6L80... I just swapped out the gate plate and made the changes I wanted. I have a B&M pro ratchet or something like that, same as billavista's writeup. The difference between the shifters application is the gate plate and the hardware kit that comes in the box.
I'm pretty sure the lokar shifters do have some sort of detent to them. There is a button on the top of the knob that locks out park or reverse. At least from the few I have played with.
Old February 18th, 2011, 03:22 PM   #316
bbaXJ
Yooper In Training
bbaXJ's Avatar
Becky, have you ever actually used one of the Lokar shifters? I drove a rig with one for about 5 minutes and absolutely HATED it. The only worse method of shifting I could think of would be cutting a hole in the floor and reaching down to move the linkage by hand. I loved the B&M Megashifter ratchet shifter I had in my old Chevelle but I still think the Art Carr/Winters gated style is the best out there for offroad. Since you don’t like that kind I say go for the modded Pro Ratchet like others seem to be happy with.
Now that I think about it I’m pretty sure I’ve still got a new Winters shifter sitting around that I need to sell…..
Old February 18th, 2011, 04:13 PM   #317
jeepbrattt
Originally Posted by bbaXJ View Post
Becky, have you ever actually used one of the Lokar shifters? I drove a rig with one for about 5 minutes and absolutely HATED it. The only worse method of shifting I could think of would be cutting a hole in the floor and reaching down to move the linkage by hand. I loved the B&M Megashifter ratchet shifter I had in my old Chevelle but I still think the Art Carr/Winters gated style is the best out there for offroad. Since you donít like that kind I say go for the modded Pro Ratchet like others seem to be happy with.
Now that I think about it Iím pretty sure Iíve still got a new Winters shifter sitting around that I need to sellÖ..
Well get your ass out in the garage and look! Whats the hold up? That back and forth bullshit is what I hated about the gates on the Art Carr......if the gates can be modified to go straight to reverse, i think i would be just fine.
No, ive never even seen the lokar, was just such limited options for the 4l80 and that was one. I have enough temper issues without adding a shifter to the mix that will piss me off..But Bryce just opened up a new world if I can use one for a 700r4
Old February 18th, 2011, 05:43 PM   #318
95geo
newbie
95geo's Avatar
I'm pretty sure GM follows this standard when designing the detents and throws on the range selection lever on the trans.
P-R= 22 degrees
R-N-D-3-2-1= 11 degrees each.
The P-R is longer because that's what is needed to reliably actuate the parking pawl. The pawl is also designed to engage at 3mph and below, above that speed and the angles, reliefs and spring tensions are such that it will ratchet until it's safe to engage. It's been said that it's safe to put your car into park at 25 mph but I'm not willing to test the design standards on my dime.
That's enough useless BS from me.
Heres your info.
http://www.bmracing.com/PRODUCTS/Com...Grip-Pro-Stick That's the one I have, except in a different color. Notice the applications?
"Fits GM TH-400, 350, 250, 200, 700R4, 200-4R (TH-700R4 & 200-4R req. 4 spd gate plate #80712), 4L80E & 4L85E. Ford C4, C6 & AOD (AOD requires #40496 installation kit). Chrysler í66 & later Torqueflite A727 & A904."
Install instructions: http://www.bmracing.com/bmracing/ins...ruction/18.pdf
4 speed gate plate: http://www.bmracing.com/PRODUCTS/Aut...orward-Pattern
Old February 18th, 2011, 05:55 PM   #319
jeepbrattt
P-R= 22 degrees
Heres your info.
gate plate not available there at this time, but found it here http://www.google.com/url?sa=t&sourc...NInRCeVk3iCYXw
Old February 18th, 2011, 06:27 PM   #320
bbaXJ
Yooper In Training
bbaXJ's Avatar
I wasn't in a rush cuz you said you hated the gated ones! I'll check it out tonight or tomorrow and shoot you pics....I'm 90% sure I still have it.
Page generated in 0.67194 seconds with 84 queries
