. - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2011, 02:41 PM   #221
Originally Posted by John D View Post
My research shows it's actually the Jeep regulator/filter that is causing the issue, not the pump. An unrestricted Jeep pump should be more than enough (personally I am using a Walbro 255LPH in tank). Go back a few posts and look at the pics I put up. Novak now sells that kits that replaces the Jeep filter/regulator with a flow through design.
Another option would be to tap the tank with a bulkhead type fitting and drop a pick-up line in the tank with an external in-line pump.
But until you get around the Jeep filter/regulator your fuel is going to be restricted.
Edit: By "unrestricted Jeep pump" I mean no Jeep regulator; you still need a regulator to keep it in the range the engine wants/needs.
Yes, but the point is that in the 03 redesign, the regulated rail went from 45psi to 58psi. So later models can hook up an LS motor with no other modifications...
Old February 3rd, 2011, 03:01 PM   #222
John D
John D's Avatar
Missed that
Thanks!
Old February 3rd, 2011, 11:36 PM   #223
95geo
newbie
95geo's Avatar
Pressure is very important but maintaining that pressure at the maximum flow rate is the most important factor of all. I doubt a pump designed for 200hp can support the fuel needs for 400+hp. Airtex 8248- $100 bosch 044- $200 walbro 255- $175-200 It's a small price to pay to know your engine isn't going lean at WOT.
Old February 4th, 2011, 06:37 AM   #224
I have a Walbro.
With that, Walbro is a Michigan based company right here in Cass City. Let's support our own!
Old February 4th, 2011, 07:50 AM   #225
I have a Walbro.
Haha, they downsized me out of the company 15 years ago by a post-it note on my monitor! That was before the CEO went down for embezzeling millions.
Old February 4th, 2011, 09:35 AM   #226
My pump makes no noise. Since it's in my tank, I can't give you the part number.
Jason, sorry for the way it went down, but I still say support the local economy.
Old February 4th, 2011, 10:30 AM   #227
firehawk
Live Action!
firehawk's Avatar
Was always told to run it with an extra quart even in the 4.0 because the oil pressure was never good in it.
Also because the pan got pretty caved in
I know this was a while ago but it just myth that running an engine with more oil will blow the seals or is that only if you way over fill it?
Old February 4th, 2011, 02:12 PM   #228
I hope you have better luck than I have had with external pumps. I'm sold on in tank pumps.
Old February 5th, 2011, 07:01 AM   #229
Switching to a fuel cell next year .....and I had external pumps on my camaro years ago, never had an issue.
High pressure pump EFI system like you will have here or a low pressure system with no return line? Big difference.
Old February 5th, 2011, 07:11 AM   #230
Cool parts peddler
Ironman Offroad's Avatar
Agreed.
Put the pump in the tank to be cooled and lubricated by the fuel.
Old February 5th, 2011, 08:15 AM   #231
I don't know what engine you had in your 69 Camaro but if it was a vintage engine, it was running at 6 psi with no regulator or return line. Now you will be running at 60 psi, require a regulator and return line. It's a huge difference.
Why will you need a new fuel pump when you go to a fuel cell? Fuel cells can utilize an in tank pump.
I'm not saying that an external pump won't work. But, I never found a good setup. I talked to a lot of people and tried a variety of pumps. I spent hundreds of dollars experimenting. ALL OF THEM ran hot and eventually quit after a period of time. The advantage of the in tank pump is that the gasoline keeps them cool. Plus, most pumps are designed to push fuel, not pull fuel. Diaphragm pumps fail quickly when pulling. Yes, the gerotor style pumps are a mechanical pump that pulls but those are the ones that ran hot.
With luck, you are getting good advice from someone that has a good working system.
Old February 5th, 2011, 08:46 AM   #232
Tab
Tab's Avatar
Yes, the same pump could be ran in a fuel cell. Didn't the external pumps try to ruin at least 2 of your wheeling trips before you switched?
If you want to compete with this thing then it would be a real bummer to get all the way to a comp (spend the money) just to get sidelined at the worst time over a known problem.
Old February 5th, 2011, 09:28 AM   #233
Cool parts peddler
I am not trying to argue.
Just an old fart who has built a couple fuel systems (not for a LS) and had enough failures to learn from. (And I will continue to learn cause I still do not know much)
Your stock tank sender/fuel pump can be removed and a replacement installed to feed that LS.
GenRite makes a ring for the top of a tank that a Jeep style sender will mount to. Have one in the fuel cell in my POS. The sender/fuel pump hanger will allow about 4" of variation in tank depth so it should adapt to about any cell..
BTW- Bet you throw a great party!
Old February 7th, 2011, 10:21 AM   #234
Just remember, I will NEVER say I told you so.
Old February 7th, 2011, 02:55 PM   #235
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
why ask if you are just going to do the opposite
Old February 8th, 2011, 08:51 AM   #236
I went with this one for my CJ8. Not sure if the grill opening is the same on the CJ and TJ.
http://www.jegs.com/i/JEGS+Performan...52036/10002/-1
The reason I did this one is it is a double pass. The fluid enters the top passenger side, flows to the drivers side, drops to the bottom half and flows back to the passenger side. This puts both the input and output on the passenger side, which matches better what the engine outputs are.
You can do that style, just need to route a longer hose for the top one.
Old February 8th, 2011, 04:33 PM   #237
cvwindows
I think I can make it!!!!
cvwindows's Avatar
I have an external pump on my rig and my last rig also. Its a ford f250 frame rail pump that is like 80 dollars and have never had a problem and they are always in stock at advanced auto.
cvwindows is offline   Reply With Quote
Old February 8th, 2011, 05:22 PM   #238
Yeah, the e2000 and e8248 pumps I believe are Ford van pumps...
Old February 8th, 2011, 08:18 PM   #239
95geo
newbie
95geo's Avatar
I mentioned it on pirate but i dont remember if I said it here.... The E8248 made by Airtex can be mounted in the tank or on the rail. I called Airtex to see if it was possible and they said it is the exact same as an in tank pump with a different inlet.
I cant seem to find a picture of my setup..... I'm going to dig deeper!
Old February 8th, 2011, 08:25 PM   #240
95geo
newbie
95geo's Avatar
Burried somewhere on gl4x4.... found the pic, just not where it's home is!
Behold the perfection! not really... but it's good enough to get me going until some issues show up.
Page generated in 0.42566 seconds with 84 queries
