. - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2011, 02:32 PM   #201
bbaXJ
Yooper In Training
bbaXJ's Avatar
Shoulda done your research first Becky, I offered you an F-body pan when I sold you the motor That's what I planned on using for clearance....shouldn't be too hard to come by another one though. Or contact Renegade II and see if he doesn't want it, he bought it along with a bunch of other engine parts I had and my 5.3 mock-up motor.
Originally Posted by fabricator View Post
was looking for a oil cooler block off plate. didn't think they would be that hard to find. maybe a dealer only item? anyone have one?
I think it's dealer only, but they're only $10-12 if I remember right. Or if you've got a decent salvage yard nearby you could probably pull it off a 4.8L or 5.3L 1/2 ton truck for a couple bucks. Not sure which models had oil coolers and which didn't, but my 5.3 was out of a 1999 1/2 ton 2WD and had the blockoff, where the 6.0L you're working with is out of a 2004 H2 4WD and has the cooler.
Old January 30th, 2011, 03:19 PM   #202
95geo
newbie
95geo's Avatar
It isnt a "block off" plate. It is a cap that connects the two ports. 100% of the pressurized oil for the engine passes from one port to the other port, without those two connected the engine will get zero oil. A dealer will have the best part to put on there if that's all you want to do. Wide open design sells a replacement piece that has a couple fittings in it for easy accumulator or sending unit plumbing. It's about $45 if I remember correctly.
It's all in here:
Links to GM LSx Engine Questions & Info - Pirate4x4.Com Bulletin Board
Old January 30th, 2011, 03:27 PM   #203
bbaXJ
Yooper In Training
bbaXJ's Avatar
Yea I know Sean, but at the time I only had enough extra cash floating around for the motor/trans. Had to wait til after the holidays to even get this project rolling. Have to do what funds allow sometimes
Yep I definitely know how that goes!
Old January 30th, 2011, 04:04 PM   #204
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
GM part number 12577903 (cover) and 12611384 (gasket)
BAD93SBLZR is offline   Reply With Quote
Old January 30th, 2011, 08:11 PM   #205
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Becky what year is your jeep? Do you still have the engine wiring harness?
Old January 30th, 2011, 08:44 PM   #206
Fullsize4life
Kicking Cancers ASS
Ok thanks
Old January 30th, 2011, 08:54 PM   #207
somer1
You Get the Big One
somer1's Avatar
Just a note if you do use the f-body pan, it comes with the flow thru cover, so no oil cooler lines are needed.
somer1 is offline   Reply With Quote
Old January 31st, 2011, 07:30 AM   #208
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
It's all in here: Links to GM LSx Engine Questions & Info - Pirate4x4.Com Bulletin Board
Ever tap a stock one for a gage? That is what I was going to look into doing?
RIP FULLSIZE4LIFE
Old January 31st, 2011, 07:58 AM   #209
There's two types, one is easy to tap (has a boss on it), the other style doesn't have much there. Depends which you have. I have the one that has a boss on it thats not drilled, so should be able to tap.
I have heard also of removing the old sending unit, which is on the top-back, cutting the top off, and drilling and tapping the base to thread in the new adapter. I might look into that.
Old January 31st, 2011, 08:11 AM   #210
John D
John D's Avatar
http://www.hotrodlane.cc/2010%20PDF%...g2010main.html
Page 35 has a cool adapter that will allow the factory sender and has a 1/8" hole tapped for a secondary pressure switch/gauge. I made my own to accomplish this but the S&P version is cheaper/easier.
Old January 31st, 2011, 09:23 AM   #211
liv2mx
i like jungle gym's.
liv2mx's Avatar
i looked at it yesterday at kevins. there sure is a bunch of little stuff on a 6.0 you need to do, that a 5.3 already has done. the other intake was a different year so there are some vacume lines that are different he has to switch around.does not look like fun!
Old January 31st, 2011, 02:32 PM   #212
Porter
Porter's Avatar
Default Hmmmmmm
A few updated pics, she's in!
Sexy
Dirty Minds Jeep Club
DMJC WEBSITE
Originally Posted by Twilight View Post
so yeah what Ross said...
Porter is offline   Reply With Quote
Old January 31st, 2011, 04:59 PM   #213
lososjoyride00
vehicle abuse specialist
lososjoyride00's Avatar
looks like im gonna have to run faster if i spot for you this year..... damnit!
lososjoyride00 is offline   Reply With Quote
Old January 31st, 2011, 06:09 PM   #214
witti
witti's Avatar
Nice build
witti is offline   Reply With Quote
Old February 1st, 2011, 11:08 AM   #215
bbaXJ
Yooper In Training
bbaXJ's Avatar
Here's a harness for ya Becky:
Complete OEM harness for 6.0 - Pirate4x4.Com Bulletin Board
Old February 1st, 2011, 11:32 AM   #216
John D
John D's Avatar
Have you decided on your fuel system yet? I crapped out another e2000 pump last week and have been searching for an alternative since. The reason I keep losing pumps is because I was pulling it through the Jeep filter/regulator.
I finally discovered this from Novak. http://www.novak-adapt.com/catalog/f...uel_module.htm
It allows you to use the Jeep TJ or Cherokee pump/sending unit. The pressure is not an issue, without the Jeep filter/regulator it is capable of the 58 psi easily. My only question is volume. Anybody have any input on a non-regulated Jeep TJ/XJ pump volume? A Walbro 255LPH in-tank could be a solution, but if the Jeep pump is enough, why not use it?
It would be nice and quiet too with the in-tank vs. external pump.
Old February 1st, 2011, 04:05 PM   #217
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Let me guess...
...you suggested using a 5.3L?
@clarkstoncracker
Old February 3rd, 2011, 11:08 AM   #218
liv2mx
liv2mx's Avatar
from what i have read a tj need's to be a 03 or later to have enough fuel pressure to run the 6.0. they say sometimes the earlier ones will work and sometimes they wont.
Old February 3rd, 2011, 11:28 AM   #219
benny87
Young Gun..!
benny87's Avatar
03-04 went to I think 45-48 psi.
That is why I went with a different pump, my TJ was like 40 psi. So I went with the corvette goodies..
benny87 is offline   Reply With Quote
Old February 3rd, 2011, 01:26 PM   #220
John D
John D's Avatar
My research shows it's actually the Jeep regulator/filter that is causing the issue, not the pump. An unrestricted Jeep pump should be more than enough (personally I am using a Walbro 255LPH in tank). Go back a few posts and look at the pics I put up. Novak now sells that kits that replaces the Jeep filter/regulator with a flow through design.
Another option would be to tap the tank with a bulkhead type fitting and drop a pick-up line in the tank with an external in-line pump.
But until you get around the Jeep filter/regulator your fuel is going to be restricted.
Edit: By "unrestricted Jeep pump" I mean no Jeep regulator; you still need a regulator to keep it in the range the engine wants/needs.
Page generated in 0.58325 seconds with 85 queries
