. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 27th, 2010, 06:06 PM   #1
jeepbrattt
New car smell.....Mmmmmmm
Default .
jeepbrattt is offline   Reply With Quote
Old November 27th, 2010, 06:30 PM   #2
fabricator
throttle jockey
fabricator's Avatar
nice. if your going with a chevy 241 case, you can swap dodge output shaft parts on it to have a fixed rear output shaft. instead of having to buy a sye.
fabricator is offline   Reply With Quote
Old November 27th, 2010, 09:11 PM   #3
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Should be a fun swap. Good luck!
Old November 29th, 2010, 04:27 PM   #4
Mr. Beefy
BFT!
Mr. Beefy's Avatar
should be awesome
Old November 29th, 2010, 05:18 PM   #5
drew91xj
drew91xj's Avatar
front tire could use some air lol
Old November 29th, 2010, 06:40 PM   #6
Originally Posted by Mr. Beefy View Post
should be awesome
It will be so-so.
Old November 29th, 2010, 10:31 PM   #7
fabricator
throttle jockey
fabricator's Avatar
Will keep that in mind Kevin, thanks. If you know of one for sale keep me in the loop.
you should need a 32 spline input with the 4l80e trans. the local yard has a few of them. i can get you a price this weekend on one.
Old November 29th, 2010, 10:36 PM   #8
GREASYHANDS
GREASYHANDS's Avatar
Old November 30th, 2010, 07:42 AM   #9
Bleay
sick of jackstand wheelin
Bleay's Avatar
Have you thought about using a Ford np205. You can swap in a 32 spline input and it will be a lot stronger. The low range is not as good but i think the torque of that 6.0 will make up for that. I think you will end up blowing up that 241.
I think you could get a Ford 205 for @ $100.00 and the input it $189.00
i'm sure you needed anopther opinion on your build.
Bleay is offline   Reply With Quote
Old November 30th, 2010, 08:30 AM   #10
Bleay
Bleay's Avatar
I checked with Dale Strobel on that ( he had a 205 for sale), he looked and said there was no adaptor to fit the 205 with a 4l80E
seems it's a big cost IF you can find an adaptor 4l80e to a Ford np205 - Pirate4x4.Com Bulletin Board
I did some research on this awhile back when i was thinking about swapping one in. I am pretty sure the bolt pattern on a ford 205 is the same as your 4l80e. I also emailed Northwest Fabworks and asked if their 32 spline input can be used in a Ford case. Their answer was yes.
Info:
http://www.high-impact.net/transmiss...case_NP205.htm
http://www.northwestfab.com/input.html
Old November 30th, 2010, 09:03 AM   #11
lowlock
05 LJ in progress
lowlock's Avatar
Who is doing the wiring harness for you
lowlock is offline   Reply With Quote
Old November 30th, 2010, 01:21 PM   #12
Jim's Performance will be doing my harness and reflash on my 5.3.
Old November 30th, 2010, 03:32 PM   #13
tw1st3d5
tw1st3d5's Avatar
Havent gotten that far yet. I know Jimmy at Extreme has a guy who does it, or there is a place i can send it that will flash it for abou $300. Do you have someone locally John?
Wayne Hartwig on pirate does lifetime flashes for $150. Seems to be getting a really good rep over there.
Old December 1st, 2010, 08:41 AM   #14
lowlock
05 LJ in progress
lowlock's Avatar
Jims Performance in Maryland, Best guy i ever delt with. Sent him the harness and ecm told him what trans,tcase,tire size and gear ratio.
I sent it to him he called me in 2 days said every thing tested great labled all wires and told me what fuel pump to buy.
Old December 1st, 2010, 08:45 AM   #15
x2. He asked me what I wanted to do with it, how radical or stock I wanted to be, etc. Came back with all the excess wires pulled out the harness and all wires labeled for easy hookup. Expensive but quality.
Old December 1st, 2010, 09:01 AM   #16
kwiers
kwiers's Avatar
if intersted i sent you a pm... i have a ford np205 that i bought parts to convert over to run behind a th400.the output shaft is the same spline count and size as the 4l80e. ran it for a season. i have changed the driveline and now i dont need it
kwiers is offline   Reply With Quote
Old December 1st, 2010, 09:15 AM   #17
That guy is a jackass. His deleted thread was full of him stating so much shit that was wrong he had it deleted to cover up his stupidity. He's so ignorant he told Bryce his mail order tune would out perform any tune Bryce could get done on a dyno...........cause MI doesn't have anyone good at dyno tuning LSX engines I wouldn't send him anything even if it were for free. My $.02
Old December 1st, 2010, 12:08 PM   #18
Cool parts peddler
Ironman Offroad's Avatar
I stand corrected.
Lesson for me in only going to a couple sources for info.
Sorry Becky.
Old December 1st, 2010, 12:49 PM   #19
Bronc j-8
49726
Bronc j-8's Avatar
lt1350.com did mine. they do Lt and Ls harnesses. cost me about 400 bucks for them to make mine a stand alone harness,delete mass air flow senser and reflash and upgrade ecm(you get about 10hp). And you get $50 reflashes for life.
Bronc j-8 is offline   Reply With Quote
Old December 1st, 2010, 03:33 PM   #20
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
H'mm, I had not heard about that?
RIP FULLSIZE4LIFE
Page generated in 0.34769 seconds with 84 queries
