95 f-150 body lift question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2010, 02:56 PM   #1
redneck942
redneck942's Avatar
Default 95 f-150 body lift question
I got a 95 f150 and i am planning on putting a body lift on it to fit a little bit bigger tires on it to get around the swamp. it has the 5 speed manual in it and i was thinking the other day that if i lift the body the hydralic line to the clutch slave cylinder wont be long enough and its not going to bend because its the dumb hard plastic line so if i buy a body lift will it come with that or do i need to cut the line and extend it with a rubber line or what do i need to do. any advice would be appreciated.
redneck942 is offline   Reply With Quote
Old November 27th, 2010, 10:02 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
The clutch line will be fine.
The transmission shifter and 4x4 shifter may need some modifications.
Old December 29th, 2010, 10:10 AM   #3
redneck942
redneck942's Avatar
thank you yeah my dad had a ford he put a 2 inch body lift on and he said he had to modify the shifter a little bit but i was just curious because the clutch line is the hard plastic and so its not going to flex well so i was just curoius
Old December 29th, 2010, 10:21 AM   #4
6boltfreak
6boltfreak's Avatar
Send a message via Yahoo to 6boltfreak
i belive if you disconect one of the brackets that holds it close to the body, it should give you enough flex for your body lift. but like jeeperz said transmission shifter and 4x4 shifter may need some work. good luck, show us some pics when your done.
6boltfreak is offline   Reply With Quote
Old December 29th, 2010, 07:12 PM   #5
redneck942
redneck942's Avatar
for sure I will def have to post pics I also plan on installing 4 inch suspension but it wont happen for probably about another month but pic will def come up, i will post a build thread
Page generated in 0.22869 seconds with 38 queries
