03 blazer wont start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 25th, 2010, 12:49 PM   #1
Timmy
Timmy's Avatar
Default 03 blazer wont start
I have an 03 blazer, when you turn the key to start it, it will not do anything. All of the lights, radio work just fine. Sounds like its not activating the starter. Any help.
Timmy is offline   Reply With Quote
Old November 25th, 2010, 12:58 PM   #2
indy
indy's Avatar
Sounds like a starter solenoid.
indy is offline   Reply With Quote
Old November 25th, 2010, 01:01 PM   #3
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
The anti theft could be tripped. Turn the key to run but do not try to start. Let it sit in this position for 10-15 min, until the security light starts flashing. then turn the key to off. then try to start it. You may need to repeat this 2 or 3 times
BAD93SBLZR is offline   Reply With Quote
Old November 25th, 2010, 03:42 PM   #4
Disturban
Disturban's Avatar
Also check the starter fuse.
Old November 25th, 2010, 04:01 PM   #5
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
had the starter relay go bad on a 2000. also the ignition switch in the column went bad on it too. a couple things to check.
Old November 25th, 2010, 04:48 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
Ignition switch. I've done a few of them. Mine does that once in a while but it does still work, unless it's crabby.
Old November 26th, 2010, 03:34 PM   #7
Timmy
Timmy's Avatar
Well i smacked the starter this morning and it started. So then I pulled the starter and took it up to be tested and then it failed. Does this sound about right?
Old November 26th, 2010, 03:47 PM   #8
ChevyRacer1981
solenoid then change starter and should be good to go.
Page generated in 0.25486 seconds with 47 queries
